Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Very gusty wind here in Detroit.  15-30 mph easy... took off in alt hold. VERY impressed, Pos hold too,,, very impressed. Rock solid it just hangs there like it's on a rail!!!!!!!!!!!!!!
    The only thing I notice is my throttle stick seems different. %50 holds fine but it seems different somehow. Was there a default something  with 3.3 and throttle settings??? It's like the dead band got bigger? Is it just me? Is it intentional?   But wow!!! Is the major improvement because of EKF???  I have turned that on and off before.... but this flight characteristics now are way better. Love it... thx devs!!!
    • Hi Richard, I live in the thumb. Nice to see a fellow Michigander. Go Lions! Meow!
      • wow your kidding.. I have a place by lexington. Looking forward to 3.4 and 'boat mode' for some killer lake Huron footage :]
    • *with about 45%
    • Hi Randy! I think its a big bug... My Quadcopter does take off in stabilize with ca 45%, and in loiter or alt hold with ca 80%. Why?
      Richard,
      Txs for the feedback.  Maybe the EKF helped but my guess is much of it is Leonard's work on the attitude controllers and also the improved thrust curve (it was a set of three lines but now it's a smooth curve).
      We did resolve a small bug in the throttle input code which we never noticed until more people started flying with sprung throttles (in particular the Solo).  Fixing that did slightly adjust where mid throttle and the deadband are.
  • what is going on with 3.3.1 ?
    I had for long time 3.1.5 my OEM Pixhawk was flying perfectly
    then 2 weeks ago I upgraded to 3.3 . did full wizard from Mission planner. I found out that THROTTLE is not cutting directly to my input but it is delayed and somehow props are still spinning for 1 second when my throttle was down. Then I tried GPS mode and it was not keeping position at all , attitude mode was working ok, and stabilize mode ok.
    then yesterday I updated to 3.3.1 and now I got BAD GYRO HEALTH on mission planner but artificial horizon looked ok, I tried the wizard again and it FAILED on accelerometer test . I ignored it then went outside  and right from the start CRASH like gyros would not work at all. so what is going on ? instead working better and more user friendly looks like programmers make our life worse. I think I will go back to 3.1.5 when all was predictable and working fine.
    if anyone cares I can add my logs. I mostly fly on stabilize mode and atti.
    mu setup : 500mm quadcopter frame , with pixhawk and 3dr power meter and 3dr GPS.
