Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Sorry for the messy post guys, I'm trying to work out some internet problem on my computer. I'll fix this up so it makes sense when I can.
thx for clarification...
Hello friends.
I've been testing COPTER 3.3 rc1, and I detected two problems.
The first problem is the continuous variation notice EKF, although in three hours flying this BETA version, had no problems or faults with the EKF filter.
The problem was flying in drift mode when landing, and disarm engines, quad leaned over and touched the ground.
I am very satisfied with this version and very grateful for your work.
best regards
I am also getting EKF Variance when arming. I was still able to arm and do a short flight in Stabilise.
@Randy Is it ok to fly with this warning? Are the tolerances too tight or is it indicating I need to change my setup?
Glenn,
I think it will be safe while you're in stabilize but it won't let you go into autopilot modes like Loiter, RTL. So in case of a failsafe it will likely switch to pilot controlled Land.
I'm pretty sure we have some thresholds set too tight so we're not letting the user into the autopilot modes when we probably could. All those thresholds changed when we moved from inertial nav to EKF and it also seems like we're not giving as much information about what the EKF is waiting on (it's normally for the EKF estimated velocity to fall).
Yes
Tested rapid ascents and descents with an over powered 650 quad. It has 3508 580 kv T-motors and a dampened mobius cam (no gimbal). No question 3.3.1 is way more better. The video proves it. The first two descents were very unstable and the wind was light. With 3.3.1 loaded 2 days later the wind was out of the NNE, and pretty strong. Up high in clean air the descents were very stable. The second descent in 3.3.1 was actually in stabilize mode(the caption was wrong) at ~ 8% throttle not touching the right stick, and it was the most stable. Well done Leonard!!!!
http://youtu.be/n4Bcq2ImsHI
Thanks Greg,
It is nice when things work the way they are supposed to :)
Greg,
Thanks for testing that. Indeed the descents in Loiter/AltHold do look more stable using AC3.3.
place in video when descending with AC3.2.1 is here
equivalent for AC3.3-rc1 is here.
What was the WPNAV_SPEED_DN value set to?
428
429
430
431
432
of 449 Next
