Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I've recently seen the behavior you are describing as well, but I don't believe it is related to the problem I reported here.   The issue I reported in 2266 only causes small constant errors in roll or pitch.  I did submit a pull request for 2266 last night.  If you can't find the cause of the erratic behaior, you may want to file a separate bug.
  • Tryin 3-3-rc3 on small 600mm CF quad.
    - Could not calibrate accelerometers on the table using radio link. Was successful using USB link first go. ??
    - Compass calibration even with 2,500 + points didn't "auto accept" (using radio link)
    - Radio calibration using Taranis and "native" channel order (e.g. Throttle on channel 3 instead of normal 1) was easy through radio link.
    Using Quanum telemetry, I did disable on board failsafes related to battery..
    Flying test:
    Take off was smooth and easy in stabilize.
    Moving on to ALT Hold was very good.
    As soon as I changed to loiter, the quad decided to go where he felt better and crashed.
    Perhaps someone could tell me more about it looking at the attached bin file?
    Thank you in advance.
    Henri
    • Bin file didn't upload..
      2015-05-09 15-30-50.bin
      • Hi Henri,
        What GPS module do you use?
        I hope that the developers look into this, I had exactly the same issue with 3.2.1
        • Using M8N
          Not sure:
          - Mission Planner 1.3.25.3 and 3.3-RC3 (11th May 2015)
          - Shielded audio cable in between the Pixhawk and the M8N (no more noise on SDA line)
          compass calibration was really easy. and both internal and external were showing on the nice "calibration balls"
          Accelerometers calibration went fine with radio link. (no need to use USB to do so now)
          After powering it off and back on, after calibration,  the altitude was correct!
          So it does looks promissing..
          Henri
        • Good morning Geert.
          Using this one: M8N. But after the crash, I decided to investigate the compass side. So I connected an oscilloscope onto the SCL and SDA lines (directly on the little tower 15 centimeters above the Pixhawk) to see if anything was not correct. Well even the I2C clock line looks ok the I2C data line (SDA) is very noisy and small spikes are very visible on the scope.
          Now running each SDA and SCL line on shielded audio cable to improve the noise margin. I am surprised as normally 400 pF is possible by the I2C standard. Don't know where this "coupled noise" is coming from.
          Henri
          • Hi Henri,
            Two qeustions:
            1. Could you use a ferrite ring to lower the noise spikes of I2C signal?
            2. Did you use somekind of stereo shielded cable?
            Thx
              Please reference section 7.5 of http://www.nxp.com/documents/user_manual/UM10204.pdf
              7.5 Wiring pattern of the bus lines In general, the wiring must be chosen so that crosstalk and interference to/from the bus lines is minimized. The bus lines are most susceptible to crosstalk and interference at the HIGH level because of the relatively high impedance of the pull-up devices. If the length of the bus lines on a PCB or ribbon cable exceeds 10 cm and includes the VDD and VSS lines, the wiring pattern should be:
              SDA _______________________
              VDD ________________________
              VSS ________________________
              SCL _______________________
              If only the VSS line is included, the wiring pattern should be:
              These wiring patterns also result in identical capacitive loads for the SDA and SCL lines. If a PCB with a VSS and/or VDD layer is used, the VSS and VDD lines can be omitted. If the bus lines are twisted-pairs, each bus line must be twisted with a VSS return. Alternatively, the SCL line can be twisted with a VSS return, and the SDA line twisted with a VDD return. In the latter case, capacitors must be used to decouple the VDD line to the VSS line at both ends of the twisted pairs. If the bus lines are shielded (shield connected to VSS), interference is minimized. However, the shielded cable must have low capacitive coupling between the SDA and SCL lines to minimize crosstalk.
            • Hi Geert.
              Ferrite rings are more (or less) not  good news for the flight controller mag sensors.
              Yes I used plain small shielded audio cable and that did improve nicely the spikes on the SDA line of the I2C bus.
              I guess a twisted  pair cable of ground + sda signal should do an equivalent task.
              No matter what it isn't a good idea to have relatively fast signals traveling long distances ( 10 centimeters or more ) without a ground data signal in between them.
              Henri
      • Found a weird issue with the latest beta version of MP 1.3.25.2 build 1.1.5599.32514 and firmware 3.3rc3.
        When I loaded up the firmware it was taking forever for the parameters to download.  I waited 30 minutes or more but they never completed.  I could cancel out but then some of my parameters wouldn't come across so I was prompted to do all of my calibrations all over again.  I wasn't able to select frame type either.
        I rolled the firmware back to 3.2.1 and everything is normal.
        Yes, I believe that this is a MP problem but thought that I'd throw it out there to see if anyone else has experienced this?
        -Mike
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
1 hour ago
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
1 hour ago
7 hours ago
Saturday
Saturday
Saturday
Friday
Thursday
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
