Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Randy, Thanks for reply.
        In my opinion it looks like the glitch detection feature is not completely implemented.
        Its a nice feature that the controller detects a GPS glitch, but when the situation ends up in a crash, there should be another handling for this situation in the 3.3 code.
        Maybe there are some changes in the EKF part possible that leads to the same behavior as I saw with other EKF issues i saw in the past (switching to Alt hold, beeping, blinking, maybe this could only be overrided if switching to alt hold and then to another mode so that the the copter did not automatically goes back to GPS).
        For 3.4 it would be fine if there is a GPS glitch failsafe.
        Hopefully there is a chance to make the 3.3 more safe in GPS modes.
        Cheers
        Gregor
      • Having suffered a lot of GPS signal lock losses I'm going to have a look at my logs from Sunday. I was operating in Alt Hold mode most of the time so I may have dodged the same issue here.
        I like the drop into Alt Hold mode on GPS glitch and having multiple options would be ideal
      Hi Gregor,
      I am very sorry to hear about your crash and damage!!!
      This is a GPS glitch by the looks of things. I will need to talk to Randy about what happened here but it looks to me like you had a short GPS glitch that wasn't long enough to throw you out of Loiter but when the GPS came back the errors in the GPS position caused the copter to suddenly adjust itself. It looks like the copter would have settled itself quite quickly.
      I always recommend switching to Stabilize in any situation resembling what happened here. Stabilize gives the pilot the best hope of recovery and also gives the pilot the most direct control over the throttle and therefore the ability to kill the flight or attempt a controlled descent.
      I will chat to Randy and see if there is anything else we can tell you.
      Again, sorry to hear about your crash!!
      • Hi Leonardt,
        I thought when moving the Copter in Loiter, it is nearly the same as stabilize. Only when the sticks released its using its positioning features. But I think I was wrong.For the future I will program a switch for emergency (stab mode, landing gear). I was unable while trying to prevent a crash to the trees, dialing a 6 pos dial of the FrSky.
        It would be very nice to get some other suggestions about how to prevent fast autonomous movements in GPS modes, because the manual rc overrride seems to be no solution.
        • No, Loiter mode is fully automated controls all the time. Stick inputs are demands for measured acceleration/velocity, not lean angles such as in Stabilize.
          Yes, you are correct, that mode switch knobs are a poor choice as it's very difficult to get the mode you want quickly in a panic.  Heck, it's difficult even at the best of times.  Having a mode like Stabilize on a panic switch would be a good idea, but will probably require a complicated mix in your Tx.  One option would be to put Stabilize at the extreme end of your knob, so that all the way counter-clockwise was Stabilize.  Then you just grab it and turn it till it stops.
      • Hi Leonard,
        Regarding the GPS Glitch, several question:
        1. Switching over from main GPS to secondary GPS location still causing some suddent movement on the multirotor, is it fixed already?
        2. I have soo many GPS glitch (more than 50) when moving with speed above 15m/s, but only got around 2 glitches when moving on 5m/s speed. Any parameter that I should modified? perhaps increasing the GPSGLITCH_ACCEL ?
        I'm pretty sure that both issues are happening on 3.2.1 and 3.3
        • Hi! I have compile the code(changed some values in v frame) back at end of june.
          Now when I configure the copter,I have discover that I have Firmware V3.4-dev(1a9cdac4)(It is written at top of misson planner and in the dataflash logs it is also written that it is v 3.4)
          But when I look at the readme txt in the code I have compile from,at the top at the text file it says
          it is 3.3-rc7 28-june-2015.
          So now I wonder do I really have V3.4-dev(1a9cdac4)? or is it V3.3-rc7? And can you recommend
          any of this firmware?Or do I have to recompile it using 3.2?
          I have only test flight it 3 times in stabilze and alt hold.And the latest flight I did a autotune
          After that it "jumps" when I yaws.When I checked the pids the p yaw is at 2.0 and I at 0.2.
          I wanted the stable version 3.2 when I downloaded the code but I must have take the wrong one...
          So I just wonder If I have 3.4 is it to risky to use it?
          • Hi Stefan, this really isn't the correct place to discuss this but I'll give you a quick answer here.  I can't track down your git hash, but it's almost surely that you are compiling Master which has diverged from the 3.3 branch.  But it also seems quite old.  So this is probably the worst thing you could be doing.
            You should definitely be using 3.2.1 if you don't know what you're doing.  Best place to get it is directly from Mission Planner.  If you must compile on your own, then here is a link to the 3.2.1 branch here:
            https://github.com/diydrones/ardupilot/tree/ArduCopter-3.2.1
            • Thank you Rob for the answer! And sorry for posting here....
  • Ooops!
    My 690 Pro 3.3 rc11 shed a propeller over the weekend. I'd just fitted a set of quick release hubs and one may not have been as tight as all the rest. How it unscrewed against the resistance of the prop is a little disturbing ( yes I do have the left hand and right hand threads on the right props! ) The good news is that the software recovered in about 3 rapid rocks from side to side. It immediately started to lose altitude from about 25m and managed to land completely flat in a patch of unmowed grass about a foot long with zero damage!
    On Sunday after a thorough airframe check I had 2 18 minute plus flights ( 10000mah liPos ) in absolutely dead calm conditions on a glorious UK autumn evening. The loiter capability is awesome with the vehicle all but dead stationary.
    No detectable prop hub loosening. I'm wondering if these hubs are a good idea or not. Loctite seems counterproductive!
    Although I am running twin uBlox GPS's ( M8 primary  and M7 secondary ) I am getting repeated 'GPS signal lost' reports and for a lot of the 40 minutes or so I was airborne I was operating without GPS signal reported to Tower.
