Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                    Hi Pomaroli,
                    Yeh, that has the new Autotune in it. Give it a go and let me know how it goes.
                    The heavier wiring might change things a little but not much.
                    Thanks!!
                  • hi Leonard, i'm just finished today updating the power system to AWG10 cables and XT90 plugs. just wondering if this will make a difference.
                    I've seen in the firmware repository that there is a newer version of RC1 with date 2014-04-15 is it the newest autotune version ?  shall i give it a try or wait for RC2   ?
    • Thank's Randy, no Pixhawk for the moment but in wish list for this year :) :I think I find an issue in land mode but I have to do another check and post in the correct post (3.2.1) during next week with logs.
  • Sad to see APM dropped.
    • Hi !
      Would it be possible to compile for APM when disabling some of the options ?
      (In the .h file only flash savings are mentioned, no idea of CPU and RAM savings).
      Any hope for that ?
      Greetings,
      Nils
        Nils,
        No chance I think.  There's a massive increase in the number of calculations being done with the EKF and the older, simpler inertial nav (complementary filter) has been removed.  If you're really keen to keep going on the APM2.x boards then sticking with AC3.2.1 and if you're looking to add new features, then working off that branch is best.
        • Hi !
          Thank you for the quick answer. I am fine with 3.2.1. I guess i will wat for a killer feature and then upgrade to Pixhawk. APM 2.5 & 2.6 clones are now sold for < $40, WOW :-)
          Nils
          • These kind of systems will even get cheaper. One day everybody will be able to afford some brand or another.
            I remember the systems like Micropilot, Hellicomand Profi/GPS and as such years ago when these systems were just coming onto the market. Each system was costing a fortune. Lol...
    • All good things come to an end ...Pixhawk 1 or 2 shopping time.
      • Sure. It would be nice to know the Pixhawk's shelf life before making a purchase.
        My APM 2.5's usable life was less than 2 years and that is with adding an external compass and some other improvements to keep it current.
        Yes, it is still running and usable but now will no longer be a current FC sadly.
