Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I have been having one small issue ever since 3.3 RC-1. I have yet to see a landing detector disarm. I have been landing in loiter mostly. I just go to stabilize and disarm. I remember it working before with 3.2.
    I am also getting the vert ekf error, but the bad ahrs warning went away with rc5. Will test rc5 shortly. Yesteday was  rc4.
  • I am very much convinced at least one EKF error is a result of the recently updated MP. My large Y6 which is on r3 had zero errors after many flights. Today I connected to MP and right away a EKF error pops up.
  • I was recently flying my quad with 3.3 RC3 and it suddenly flipped into the ground. I have attached the log. I ran the auto analysis and it failed the brown out test. I never had this issue prior to the 3.3 update.
    Here is the log.
    Any help to determine the failure would be appreciated so that i might avoid this is the future.
    It is using a PixHawk with 3DR Power Module
    Joe
    2015-05-12 18-38-29.bin
    2015-05-12 18-38-29.log
      Hi UAS_Pilot,
      I can confirm looking at the logs that the autopilot wasn't running when you crashed. It looks like you lost power to the pixhawk.
      Sorry about your crash!!
      • All connections were good on the airframe. Not sure why the brownout. I will be rebuilding it. I don't think vibration caused any issues, during this flight I was flying pretty hard whil in stabilize mode.
        Thanks for the information I will look over the system really good during the rebuild.
        • This reply was deleted.
          • Thanks for the info. I will replace the PM and the cables.
        • In my case I had brownout because of APM power module. As funny as it sound it just had not enough power. 7.5A BEC resolved problem.
    • I haven't looked at your logs, but if it was indeed a brown out reboot it is not a software issue. That's hardware. Check power connectors that could be intermittent with vibrations. If the log just stops, it reset for what ever reason.
      • I get that, But why would this start when I updated the firmware. I have flown it with 3.2.1 for 3 months with no problem. Just wondering. I will look over all parts on the PM and cables when I rebuild.
        Joe
        • Perhaps vibrations affect a connection?
          3702786680?profile=original
