Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I tried clearing the logs and did another test flight. The same error occurs when doing autotune. It seems that this is a Mission Planner error though, not Arducopter error.
I have been having one small issue ever since 3.3 RC-1. I have yet to see a landing detector disarm. I have been landing in loiter mostly. I just go to stabilize and disarm. I remember it working before with 3.2.
I am also getting the vert ekf error, but the bad ahrs warning went away with rc5. Will test rc5 shortly. Yesteday was rc4.
I am very much convinced at least one EKF error is a result of the recently updated MP. My large Y6 which is on r3 had zero errors after many flights. Today I connected to MP and right away a EKF error pops up.
I was recently flying my quad with 3.3 RC3 and it suddenly flipped into the ground. I have attached the log. I ran the auto analysis and it failed the brown out test. I never had this issue prior to the 3.3 update.
Here is the log.
Any help to determine the failure would be appreciated so that i might avoid this is the future.
It is using a PixHawk with 3DR Power Module
Joe
2015-05-12 18-38-29.bin
2015-05-12 18-38-29.log
Hi UAS_Pilot,
I can confirm looking at the logs that the autopilot wasn't running when you crashed. It looks like you lost power to the pixhawk.
Sorry about your crash!!
Thanks for the information I will look over the system really good during the rebuild.
UAS_Pilot,
From the log it looks like you didn't have a brown out, you had a black out! That makes the fault tree look pretty simple:
1. The BEC on the power module failed (a second BEC connected to the servo rail will protect against this)
2. The connection from the power module to the Pixhawk failed (loose connection, bad solder joint, wire on the connector not making good contact, e.g., bad crimping).
3. The connection between the power module and the battery failed (bad solder joint, loose connector).
4. Internal fault in the battery
Good luck.
In my case I had brownout because of APM power module. As funny as it sound it just had not enough power. 7.5A BEC resolved problem.
I haven't looked at your logs, but if it was indeed a brown out reboot it is not a software issue. That's hardware. Check power connectors that could be intermittent with vibrations. If the log just stops, it reset for what ever reason.
