Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
On the tree it shows 250 and on the list 300 so not sure which value is active and will be writen to the controller.
Hi Pomaroli,
Save the parameter file and see what it says there.
Peter,
mainly i use it for Acro and FPV and rare also for auto flight and all the other cool stuff i don't want to miss.
Acro with the pixhawk, is it as good as the naze32 with cleanflight or baseflight?
And what are your specs of the acro machine with pixhawk?
Hi Peter,
That is a hard question to answer. I has some advantages in the basic ACRO performance and probably some disadvantages.
Some of our advantages is our throttle linearisation is much better than TPA. We have a variable Yaw mix that lets you tune the point at which your copter spins out rather than roll roll or pitch (very extreme flight here). Depending on the controller and pid choice you have the pixhawk will provide significantly better stability at maximum and minimum throttle. The other big difference between Arducopter and some of the other autopilots in ACRO is we use a stabilized acro controller. That means that when you are going through extreme maneuvers (fpv racing), the copter may cavitate and drop a prop but it will bounce back to your last position.
All this is heavily dependent on how well you set up the controller and this setup wouldn't be practical if Autotune didn't do most of the work for you. We are also working hard to ensure we can squeeze every last bit of performance out of a given frame.
The other point I want to highlight: There is great work being done in all of these autopilots and they are achieving fantastic performance, the points I made above may not apply to all other autopilots. Arducopter is a little behind in some small areas and way ahead in others. Because we aspire to be the best across the board it is hard to push the development of ACRO as fast as I would like to.
What I can confidently say is that the pilot will be the biggest limiting factor given a well setup and manufactured copter.
I would say the biggest disadvantage arducopter has in this space is the size of the controller. I am hoping we can get a next generation micro pixhawk in the formfactor of the naze32 / multi wii boards.
Still to be implemented is full quertonion stabilization (currently use euler angles). We want to do an update of the code to run the rate loops with the gyro read and bypass the io chip. This will ensure we have the absolute minimum latency and jitter. To improve acro further we will need new ideas.
For smaller Copters i would go for a multiwii just because of the missing room for bigger Controllers and the fact that there are good Community support.
It would be really nice to see a Pixhawk mini from 3DR.
@Craig i've seen such coming from China, but there are still a lot of adaption to do.
Did you see some fully compatible ?
Other than the wires they are fully compatible. They are "full" pixhawks as far as the firmware/GCS is concerned.
2 issues I have with them are [and now there is a V2 that fixes one of them] all the leads are wired backward, so the PM has to be re-wired and it has no speaker or battery.
But it's 1/2 the size and weight and now you can even get them in a case :)
Hi Leonard,
Thx for the great explanation and for me the pixhawk is indeed way ahead of other pilots and if not it will be (on some areas) with this great support from the developers
When the new (mini) pixhawk is released I will sure try it on a mini acro fpv racer
There are quite a few "mini" out already. They are called Pixhawk Lite. And they work really well.
yes i did but it doesn't took effect..
