Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Did you do an auto tune with rc7?
      re- Switching from APC SF to MR may have contributed to that.
      Sorry for my ignorance is SF slow fly? What is MR?
      • I did with rc6 but last night just updated to rc7 to see how it flies.
        Auto Tune has greatly improved since 3.1.5, but I'm finding that the more flexible the props are, the more tinkering is required after Auto Tune, particularly on heavier copters. I think it is because when it gets windy, the props flex causing the copter to become more unstable which the FC must compensate for and Auto Tune cannot predict. Also during Auto Tune the PID's are much different between stiff props and flexible ones.
        Steadidrone likes SF props over MR and CF, but I'll bet they do a lot of fine tuning outside of Auto Tune to get everything smoothed out because 14x4.7 SF props are very flexible. They say MR props are for higher kv motors, but I'm finding they are actually more efficient and make for a more all around better performing craft, at least for my stuff.
        I really noticed this on the 750 Y6 when using Tarot/Gemfan CF props; get a fairly strong cross wind and the copter would dance and/or oscillate up and down because the props bend. The Tarots were the worst. Once I put the Xoar wooden props on (15x5 top 14x7 bottom), the stability was excellent in all conditions. Then I put the T-Motor props on (15x5 top/bottom) and the efficiency improved plus kept stable.
        As much as I like to rely on Auto Tune, and as good as it is, I really need to dig deep into learning how to do doing some manual tuning to make it "perfect".
        • I most definitely noticed the same thing regarding prop stiffness and how it can change how a copter behaves! So much so I had to tweak the PIDS when I went from flexible to CF.
          Hi DG,
          I suspect you are correct on the points you make here. Flexible props will also bend more in forward flight in general.
          The thought I had as I read your post was "I wonder if the vertical noise I see on stiff props is reduced on more flexible props?"
          Thanks!!
        • DG, do you use SteadiDrone units? What model? Can you share your PID?
      • SF = slow fly
        MR = multi rotor
        http://www.apcprop.com/category_s/28.htm
        Pretty new offerings from APC and they've been steadily adding more sizes to their list.
        -Mike
      DG,
      Yes, I did a bunch of tests of fast and slow descents a few days ago with my IRIS and it seemed much better than AC3.2.1.  The change is the improved thrust curve.
      • Very good news!!!!!  Faster decent on a battery FS event is a good thing. You must be really dialing it in so to speak to even improve on that! Nice...
        • Ok, can you expain how did you get battery FS with those rc5 and Rc7? Could you post screenshot of how parameters are set in failsafe and other parameters that affect that?
          As I did not change anything on the hardware side from what it was, it all worked in 3.2 fine and does not work now with any 3.3 version and i cannot understand why.
          • My bad it was just a hypothetical scenario. How are you setting it up? With which ground station?
