Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        Yes, as DG says, the recommendation is not to use two GPSs until Copter-3.4 because of the jump if it switches the primary GPS.  Master's has about 1/2 the fix already so hopefully the full solution will be in Copter-3.4.
        • Hi I used to have two 3dr gps but it kept jumping say a couple of meters so I fitted a m8n which gets between 16 and 18 sats so there is no jump as the 3dr only gets 11 at most but should the m8n fail it hopefully will switch to the 3dr one and at that point I figure a jump would be better than no gps
          Stuart
          • yes I have M8N and 6M, and the M8N is always lower HDOP , but i have had then switch in flight with no issue, seems to work ok for me in that regard and i have tested it too (by disconnecting the TX wire from GPS into Pix via a relay switch)....but i dont think the issue am having here is related to having 2 GPS necessarily...
  • Hi I have a quad done auto tune flies great with 3.3.1
    When in drift mode it can reach 50mph but is OK up to 30/35 mph but above that it starts to dive loosing height tried changing max angle for all flight modes to 30' but still losses hight above 35mph
    could this be software or does any one think frame/mechanic have reached its limit on forward speed and power to keep nose up enough to maintain hight
    It's not a barometer problem as I cover whole pixhawk in cling film to keep out wind altering pressure on barometer
    Stuart
      Hi stubugs,
      Can you provide a log please.
      • Hi did you manage to look at my log
        Stu
      • hi please find attached log
        many thanks stuart
        2015-11-08 13-28-14.tlog
        https://storage.ning.com/topology/rest/1.0/file/get/3702725746?profile=original
          Hi stubugs,
          Sorry, I need a data flash log.
        • Nice setup but it looks like you push the quad speed envelop to hard. Theoretical max propeller air speed with lowest measured bat voltage approx. 13.6V with 390kV motors and 5.5 inch prop is approx. 12.3m/s. To be able to move air faster increase voltage or change motors and propellers
Aug 25
