Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Is there a chance to get more serial ports working in 3.3? I am running out of ports:
      • Telemetry with RTS/CTS
      • Teensy for SPort Telemetry
      • MinimOSD
      • Gimbal serial connection.
      And in future camera control over Mavlink
      In my opinion the serial 4/5 ports on Pixhawk are not usable at the moment.
      Any news when this ports will be useable?
      Cheers
      Gregor
      • Already asked something like this, pages before, in combination with storm32. Wiki says with 3.3 it should be possible to use it ony any of the free 6P Ports which would include Serial 4 & 5. Sadly still no answer yet
          SToRM32 is currently only useable on Telem2 (or whichever is the 2nd serial port set with protocol "MAVLink").  Before AC3.3 goes out we hope to automatically detect which port the gimbal is plugged into and we also plan to add *one* more MAVlink port.
          • Would be great to use it on Serial5
    • thanks Randy :) Thanks to all the developers!
  • Hi there,
    I think, will Copter 3.3rc-2 be released on tomorrow. I have found some detail about it ;)
    1) AutoTune reliability fixes (improved filtering to reduce noise interference)
    2) Optical flow improvements:
    a) Range Finder pre-arm check - lift vehicle between 50cm ~ 2m before arming.
    Can be disabled by setting ARMING_CHECK to "Skip Params/Sonar"
    b) Vehicle altitude limited to range finder altitude when optical flow is enabled
    3) AltHold & Take-off changes:
    a) feed-forward controller and jerk limiting should result in slightly snappier performance and smoother take-offs
    b) vehicle climbs automatically to PILOT_TKOFF_ALT alt when taking off in Loiter, AltHold, PosHold, Sport (disabled by default, pilot's throttle input overrides takeoff)
    c) PILOT_THR_FILT allows enforcing smoother throttle response in manual flight modes (defaults to 0 = off)
    d) TX with sprung throttle can set PILOT_THR_BHV to "1" so motor feedback when landed starts from mid-stick instead of bottom of stick
    e) GCS can initiate takeoff even in Loiter, AltHold, PosHold and sport by issuing NAV_TAKEOFF mavlink command
    4) Stop flight mode - vehicle simply stops and does not respond to user input
    5) Aux channel features:
    a) Emergency Stop - stops all motors immediately and disarms in 5 seconds
    b) Motor Interlock - opposite of Emergency Stop, must be on to allow motors to spin motors, must be off to arm
    6) Air pressure gain scaling (of roll, pitch, yaw) should mostly remove need to re-tune when flying at very different altitudes
    7) landing detector simplified to only check vehicle is not accelerating & motors have hit their lower limit
    8) Loiter tuning params to remove "freight train" stops:
    raising WPNAV_LOIT_MAXA makes vehicle start and stop faster
    raising WPNAV_LOIT_MINA makes vehicle stop more quickly when sticks centered
    9) Other items:
    a) faster EKF startup
    b) Camera control messages sent via MAVLink to smart cameras.
    Allow control of camera zoom for upcoming IntelEdison/Sony QX1 camera control board
    c) Lost Copter Alarm can be triggered by holding throttle down, roll right, pitch back
    10) Bug fixes:
    a) Home position set to latest arm position (it was being set to previous disarm location or first GPS lock position)
    b) bug fix to mission Jump to command zero
  • Last night, I upgraded to AC 3.3 (compiled from master).  I calibrated the accelerometers.  I can arm and the Iris+ responds to throttle, pitch, roll input from the transmitter (props off).  The problem is that on my transmitter, I no longer get updated values for Sats, Battery Voltage, Flight Mode, etc.  All show 0 (except for flight mode, which shows Stabilize).  I can change flight mode -- the drone responds with a beep when I move a mode switch -- but no change in the display.  I reverted to 3.2.1 and, as before, the values update properly.  I then installed 3.3 downloaded via MP.  As with the version I built, the flight data values are all 0. I didn't see any other mention of the issue in this thread so I assume I'm doing something wrong but I don't know what.  Thanks.
    • Got an answer from devs on another forum.  Needed to set SERIAL2_PROTOCOL parameter to 3.
Aug 25
