Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Uninstall Mission Planner, restart your computer and install a fresh copy from the website.
      http://ardupilot.com/downloads/?did=82
      • i did already, but it did'nt work - so same message
        • Did you try to reformat (FAT32) the SD card.
          It seems to me that MP is having trouble detecting your FC.
          • no, ill try that today
  • I just installed 3.3rc5 on my s900's pixhawk and ran an autotune without the gimbal attached.
    Autotune ran fine, but the PIDs it gave me feel far too twitchy. After autotune was complete, giving it a push of roll input, it wobbled pretty badly returning to level, so I just landed. Trying to take off again was sketchy so I reverted to the old ones.
    my 3.2.1 manually tuned pids, vs the 3.3-rc5 autotune ones are below.
    stab roll p 4.5 / 8.8
    stab pitch p 4.5 / 10.2
    stab yaw p 4.5/ 4.4
    rate roll p 0.2 / 0.28
    rate roll i 0.18 / 0.28
    rate roll d 0.01 / 0.014
    rate pitch p 0.2 / 0.3
    rate pitch i 0.18 / 0.3
    rate pitch d 0.01 / 0.17
    rate yaw p 0.25 / 0.84
    rate yaw i 0.02 / 0.084
    Is it possible to just lower the stab p and keep the sharp rate PIDs, or does the sharp oscillation suggest they are just too high themselves?
    I have a log available if it would help figure this out.
    Cheers
    • I've just given it a manual tune now and it looks to fly best (by throwing it around in alt hold and getting it to recover quickly without overshoot with rate p of 0.18 and d of 0.13, and stab p of 5.
      The autotuned yaw feels very locked in though so I've kept that as is.
      Will put the gimbal on now and see if it still flies smoothly.
      Thanks for looking. Here's the log here.
      Dropbox - Error
      Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      • Thanks, so I'll set those params, and run autotune again with AGGR set to 0.05 once the weather allows. It's got an effective 16" disk, so I'll try an expo of 0.75.
        When you say the ATC_ACCEL params aren't loaded, is this something to do with how I used the switch, or just something that should have happened that the next RC will fix? In that run I let it finish autotune, then flipped the ch8 switch off and on again then landed and disarmed.
        • Just redid the autotune withAGGR at 0.05 and the THST params set as above, but the autotune still gave me PIDs that caused overshoot on corrections to manual roll/pitch input while in alt hold/stab. They are slightly lower than the original ones though. The autotuned yaw PIDs from this recent run (rate p 0.33) don't feel as good as the original autotune (rate p 0.85).
          I did this autotune without the gimbal, but with a ballast on front of equal weight to it. The first autotune was done with no gimbal or weight, but I repositioned the battery to be centered on the frame. The problem I'm trying to solve is the whole gimbal being shaken when it is attached. Have tried several gimbals. I'm pretty sure this can be solved with pixhawk PIDs. The previous manually tuned PIDs (rate p 0.18/rate d 0.14) ended up still shaking the gimbal.
          There is some manual flight in alt hold with the tuned PIDs at the end of the log.
          Log here
          Dropbox - Error
          Hi Glenn,
          If you don't touch the switch after autotune is finished, land and disarm, then switch the autotune switch back to the off position. Then you can take off with the new pids and ATC parameters. Just be very carful as you first take off.
          Thanks!!
        Hi Glenn,
        I have spent a long time looking over your autotune and I can't see anything wrong the the tune itself.
        It does look like you need to set your
        MOT_THST_BAT_MAX,
        MOT_THST_BAT_MIN,
        MOT_THST_EXPO.
        Expo is 0.65 for 10" props 0.7 for 12" props and 0.8 for 18" props.
        However, I don't think this was the problem. I can see that the ATC_ACCEL parameters arn't loaded when you switch using the autotune switch so that may have caused your problem.
        You may also like to try Autotune AGGR set to 0.05, especially if this is a larger copter.
        I will fix the issue I found in Autotune and it should be there for the next release candidate.
        Thanks for your help and feedback!!
