Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I didn´t even notice that there was a problem, till I read about ;-) Although I tried about most -rc. I just put the 1k resistor on and forgot about it. Since I´m not a battery endurance tester anyways, I still don´t even care about it.:-)
      PS: Btw., the recent batches (so called "quiet" version w/o TI) are coming with the mod already,if I understood Nick correctl.
      • The problem is not batt failsafe, but EKF failafe and GPS failsafe. So just think of a multipath+GPS giving you a glitch and instead of going into alt hold or land as you programmed it, GPsS failsafe is ignotlred and some "random" coordinates are being accepted as valid -> copter shoots towards those coords with wp_nav_max_speed. Does this sound as something minor for you?
        • Can you clarify something, as you seem to be well informed on this. Does they X2 have an issue that caused EKF failsafes to be ignored as the firmware thought was powered by USB? And this issues has been supposedly fixed with the latest release of rc10? So I do not  now need to use the 1K resistor mod?
            AC3.3-rc9 (and higher) include the fix for the AUAV board's usb-connected issue.  As some others have said, because of a hardware issue, earlier versions think the USB is always connected and this disables the critical GPS/EKF failsafe and the battery failsafe.  It's a very critical fix if you're using this boards.
            • Thanks, I wanted to make sure before purchasing an earlier version without the fix.
              BTW, the EKF/VIBE monitor is a great feature, probably one of my personal favorites since using AC.
          • Correct, but I don't think it's well tested yet.
            I had a flyaway on rc10 w/ my auav x2, and still don't know why...
            I dropped from 11 to 10 satellites at the time, but I'd think the average between the remaining 10 satellites wouldn't be WAY off from when it had 11!!
            Is there something we can look at in the logs that shows a definite GPS glitch?  Other than simply looking at satellites and HDOP?  (sorry, I got off topic here.)
            • Scott are you using two GPS?
        • Artem, that sounds ridicolous, indeed.
          But honestly, I didn´t have a single Problem,related to GPS or EKF FS, although I did a lot of flights with the X2 with various -rc Versions since Oct 2014,when I replaced my defective 3DR PX,.
          If it hadn´t been posted,I still wouldn´t have any knowledge.
          PS: It hasn´t be reported @ my pretty huge german X2 thread @  fpv-community.de  as well, so I´m not the only one;-) But I understand your worries,although I don´t share em.
          • IMHO the problem was, that the firmware, while running on an X2, always thinking "I'm running with USB connected", in this way Batt-FS and EKF was permanently switched OFF.
            For me this problem is solved since RC9.
            You can check it in log-files by the 9th bit of the DU32 message.
            "1" means USB-connected.
            PS: The problem has been reported in your thread:
            http://fpv-community.de/showthread.php?55875-AUAV-X2-Ein-echter-kom...
            and
            • You got me wrong. I meant,that nobody reported or claimed to have a problem with it. Your links are refering to MSDigital (You ?) who´s been quoting diydrones and Nick, who claimed to work on it. Well...
