Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
With 3.3 RC9 firmware I have problems getting storm32 (firmware v80)to work while connected to pixhawk serial 4/5.
I have used following user guide to setup both strom32 and pixhawk:
http://copter.ardupilot.com/wiki/common-optional-hardware/common-ca...
Below are detailed settings I applied to pixhawk:
SERIAL4_BAUD = "115"
SERIAL4_PROTOCOL = "1"
MNT_TYPE = "4"
MNT_RC_IN_TILT = "6"
On storm32 side I have only enabled emit heartbeat.
Above settings should allow me to control gimbal pitch with rc channel 6, but nothing happens when I use channel 6 knob on my rc transmitter.
Can you let me know if by the chance this issue is resolved in lates RC10 beta?
Or maybe there is some configuration I have missed?
Can anyone confirm that communication between storm32 and pixhawk serial 4/5 is actually working?
Both telemetry ports on my controller are used so serial 4/5 is the only I have.
I don't have a STORM32 board, but, in case you missed it, there is a bug fix in 3.3 rc10 for STORM32 serial protocol driver.
I have a Storm32 board and the issue with the serial protocol is defenitly not fixed in RC 10.
The only option is to downgrade Storm32 firmware to < 0.78.
Maybe some features work but the channel control (Yaw or tilt) does not.
No promises on the serial interface working but the MAVLink interface should work although I have not tested it really recently.
I've tested it - none of the rc channel control code was changed. I can confirm all serial mode features work. I haven't tested the gimbal in mavlink mode. This is with firmware .86e & 3.3rc10. Make sure you set the gimbal mode to rc control, the easiest way is to change the default mode to rc targeting (MNT_DEFLT_MODE).
I found my mistake: From the wiki it is not clear if we must disable the mavlink heartbeat for using serial protocol. With the older versions it works with the enabled mavlink heartbeat. But with the newer storm versions you must disable it to get serial protocol working. Maybe the serial setup should be explained a little bit better in the wiki.
Many thanks
Gregor
Great you found your issue. About the Wiki though, since it IS a Wiki you are free to sign up and make edits which frees up the devs time to actually do devvy working you know. Just saying.
Randy, Leonard,
After finally be able to download RC9, due to very bad internet connections at my current holiday location, yesterday I had the first flight with this firmware.
In the meantime read the Blog post of Leonard, about the Motor Bel Play, and the feedback from Wes which basically delivered the proof that this should bring down the Z Axis Vibrations, I removed the play on all 6 Motors (power usage is going up a little (2 amps)), as I did have quite some up and down movement on the 4114 I am using.
After taking it up, the motors already sounded much more monotone without the occasionally quick ramping up like they did in RC8, so it did fly much better as before...
In the logs however I do find clipping, but it's not going up as high as before...
Vibrations seems to be lower as well, in comparison with the previous logs I looked at
Looks like the latest changes in RC9 are working out.
Thanks Devs !
Logfile : https://drive.google.com/file/d/0BwKkz56PHqS0U1lra1BZNzBNSW8/view?u...
P.S By looking at the previous log of RC8, it seemed I did have an unhealthy barometer value as well, as somewhere just
before the uncontrolled altitude gain, the Baro switched 2 meters within 100ms, which is hardly something you can trigger by flying I guess....
I would have expected a small tweak to the EKF parameter to make the Barometer less important, but don't see the change there...? , so I guess it's done somewhere in the EKF code ?
Randy,
On this "Error Compass Variance" issue I and a few others seem to be having with Pixhawk Lites, what specifically are the 2 things that are being compared and found to have a variance, and what is the threshold? Might help if we can graph the 2 variables and see if they can be improved.
Also, one thing I have noticed with this controller. When I go into a compass calibration using live calibration and the compass dance, the calibration completes most of the time before I have completed the full dance, if that makes sense.
Thanks for your help!
Scott...
Scott, Craig,
Doing these kinds of tests you mention would be great. Make sure to provide dataflash logs of course ideally with the logged-while-disarmed LOG_BITMASK set. So far Luis and Scott have provided logs and they've shown real physical issues instead of firmware problems but in any case, more data would be greatly appreciated.
I think using the latest beta mission planner is easiest. It's got a new live EKF viewer that shows the compass variance as a bar that changes from green (good) to orange to red.
