Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • This is also a Alien 680 tuned at an aggr of .05.  The tune is is rock solid.  This is an X8 though with Sunny Sky 4108s 14 480kv motors and 15" propellers running 10ah4s packs.
          3702801679?profile=original3702631891?profile=original
  • Help!!
    I have Compass problems, calibrated OK but high offset on internal Compass. Have I done something wrong during config?
    As soon as I yaw I get EKF Compass errors it looks like MagY sometimes follows and sometimes mirrors?
    When I fly, land and disarm. and then try to arm and fly again I am not allowed due to EKF Compass errors.
    Should I try to disable the internal Compass?
    3702123511?profile=original3702123472?profile=original3702123557?profile=original
    2015-11-12 14-06-59.bin
    • I disabled int compass and all works well now
  • hi, i have run into this issue that happens sometimes but only seen it in 3.3.x releases, where pix will not enter into a flight mode that requires GPS, but the GPS are ok (i have 2 of them), all I have to do is restart the pix and then it will work fine....log attached of the issue from today....I took off in manual, went to enter loiter or auto, neither would take giving flight mode error....but far as I can see both GPS seem to be working fine....any clues?
    2015-11-09 14-27-46.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702121614?profile=original
    • The last recommendation I recall was to use one GPS until 3.4 addresses issues related to 2x GPS. Is that not correct?
        Yes, as DG says, the recommendation is not to use two GPSs until Copter-3.4 because of the jump if it switches the primary GPS.  Master's has about 1/2 the fix already so hopefully the full solution will be in Copter-3.4.
        • This reply was deleted.
          • yes I have M8N and 6M, and the M8N is always lower HDOP , but i have had then switch in flight with no issue, seems to work ok for me in that regard and i have tested it too (by disconnecting the TX wire from GPS into Pix via a relay switch)....but i dont think the issue am having here is related to having 2 GPS necessarily...
