Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                • It was a Whitespy compass that I had trouble getting the orientation right with also. It is the only compass that I have used so far that required extra work to get it right.
                  • i suspect all whitespy units are unsafe. 45mm gps unit ate battery i soldered in in fall over winter, and its gps is producing highly erratic data that causes vehicle to wander around. it is not charging battery and i am not going to solder in a replacement anymore. reading of sats also dropped from 18-20 down to 8-11, it correlates to responses from some other people. smaller 35mm unit seems to be getting more stable readings - vehicle is not hunting around that much with it as gps source but it is also reading 12-14 sats top, a m8n unit.
  • Another flight with 3.4 flew great. Just wish I could increase the PIDs but with my Mac and APM P2 I can't :[
    BTW    LASTLOG.TXT = great idea!!! probably been around a year but I only just noticed... excellent idea!!
    • You should have the full parameter list and in there you can adjust PIDs. I would have to look the names, but I'm pretty sure they start with ATC_
      • ahhh yes good point. Thanks
        • Does anyone know of a Website that has the parameter list and what the meanings are ?
          • That's one thing I REALLY like about Tower is if you select a param it actually tells you things about it. My GCS on my computer running APM P2 often just tells you you can select 0-10 or something like that for flight modes. So unless you have that memorized you don't know what to select.
          • Is this the list you are looking for? http://ardupilot.org/copter/docs/parameters.html
            Complete Parameter List — Copter documentation
            • Yes, Thank You Derek
    • why not use bootcamp, or a virtual machine, or maybe wine and use mission planner?
