Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • spock calibrated it for me... yes of course i did.. but for some reason it seemed like a drunk uncle that just got bad news that nascar isnt going to be around no more and his favorite beer is going outta business..
                but seriously once i went back to the stable release no problems...
      • This reply was deleted.
          • Thanks Phil, Kurt. Unfortunately that didn't fix it. I'm getting a 403 error from the server during the download of the dll.
  • I was wondering if this a new change that was meant to be there. In 3.2.1 using tower you could switch to Auto and without moving the throttle the copter would take off and fly its mission with out touching the R/C controller. I am trying 3.3RC11 and now in tower I switch to auto in Tower and I need to move the throttle to make the copter fly. Is this a setting I need to change or is this the way it is suppose to be for now?
    Thanks and Great work. Very smooth....
  • Not sure if this has been reported before, but setting either CONFIG_SONAR, CAMERA or AC_RALLY to DISABLED prevents Copter from building.  In the case of AC_RALLY that seems to be a simple typo, in case of CAMERA misplaced #ifdefs, but in the case of CONFIG_SONAR it seems like building without it is no longer supported?  I needed to touch up too many places to build without sonar.
  • I had a little incident today flying rc10. First off, The copter was in the trunk of my car all day and was a little warm when when it was initialized. The problem is I had had a radio fail-safe and it hit full throttle for ~ 1/2 sec and then dropped and revved up again. It hit 60 A witch is the max. Going from loiter to RTL, and once from RTL to loiter the throttle revved and then the copter jumped up then it sank back down(corrected the overshoot). I thought I just imagined it, I was flying fpv the first RTL. I watched the onboard video and confirmed that. I haven't changed any params, it must be something to do with a temp change after start up.
    2015-09-16 19-04-25.bin
      Greg,
      As discussed on mumble, after looking at the logs it looks like a baro disturbance to me.  We've recorded a few situations where the EKF doesn't deal well with barometer disturbances and the altitude estimate and climb rate estimate become inconsistent.  In this case as well we see the impossible situation where the climb rate is negative even though the altitude is climbing.
      Leonard, Tridge and I have discussed with Paul (ekf expert) and we hope the "new maths" coming in AC3.4 will deal with this situation better.  Until then the only solution is to try to reduce the barometer disturbances like tohse that happen when the vehicle suddenly slows after fast forward flight (this is what happens when RTL is engaged)
  • well i like to report my copter is performing very well since AC3.3rc10 and recently rc11.
    I believe good status should be reported as much as bad one and problems alone....and I have been lucky to not have any issues so far in over 30 flights, no complains (well except for MP not being consistent and GCSs not being able to read darn AC3.3 log files!!!)
    But anyways, just my 2 cents, based on my experiences with it I would say is ready for prime time...but thats just my take on it...hope others are having good experiences too, not just bad
    Randy and Leonard have been great when I needed any help, and in more than one occasion I was ready to blame the beta software for issues that turned out to be hardware related with the copter....
    • Hello, I would like to report a very good performance as well! Good job!
      By now I have flown more than 10 batteries without any issue. The only one that I have found was different autotune results, all of them are overshooting a little. Could be my setup, but I don't think so. Let´s wait for more autotune tests to see if there is something weird with it.
  • rc11. I'm struggling to see what's going on. The quad (250) flies quite well although is not tuned (see other posts). The compass innovations (SMX,SMY,SMZ) are too high and yet the compass calibration seems quite good with both compasses tracking each other. Vibrations appear low. No gyro drift. GPS velocity errors are low-ish (SV). Baro errors (SH) low. Any clues? Logg attached as its to hard to show a composite graphic with all of these.
    19.BIN
    • I'm getting the dreaded "Inconsistent compasses" from time to time as well.
