Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
was it your 1st autotune try? did you change anything else?
do you have a short log with stabilize and a poshold?
i don´t see my problem optical....only in log and fpv cam
greets
This is on an Alien 680 also. Flys great.
oh.cool.
was it with aggr=0,05?
i hope for better weather to test
Dear Randy
Please help me
I have change new pixhawk to my iris+ and setup fw 3.3.1 and calibration all. What is happening now is that Altitude Hold and Loiter are unable to maintain a consistent altitude. When I keep the iris+ hovering in place (either by manually doing so or using loiter), I get an altitude change of +/-1-2 Meters or more 10-20meter. This is a bit of an issue but even more so is that when I fly it laterally, it loses altitude quickly when i switch loiter to alt hold and all of a sudden pitches/rolls violently then shoots up into the sky where I have to quickly change over loiter and back to land.
thanks you so much !
here is logs file.
https://www.dropbox.com/s/8e5gffmqfuurkes/logs%203.3.1.rar?dl=0
Help!!
I have Compass problems, calibrated OK but high offset on internal Compass. Have I done something wrong during config?
As soon as I yaw I get EKF Compass errors it looks like MagY sometimes follows and sometimes mirrors?
When I fly, land and disarm. and then try to arm and fly again I am not allowed due to EKF Compass errors.
Should I try to disable the internal Compass?
2015-11-12 14-06-59.bin
I disabled int compass and all works well now
hi, i have run into this issue that happens sometimes but only seen it in 3.3.x releases, where pix will not enter into a flight mode that requires GPS, but the GPS are ok (i have 2 of them), all I have to do is restart the pix and then it will work fine....log attached of the issue from today....I took off in manual, went to enter loiter or auto, neither would take giving flight mode error....but far as I can see both GPS seem to be working fine....any clues?
2015-11-09 14-27-46.bin
The last recommendation I recall was to use one GPS until 3.4 addresses issues related to 2x GPS. Is that not correct?
Yes, as DG says, the recommendation is not to use two GPSs until Copter-3.4 because of the jump if it switches the primary GPS. Master's has about 1/2 the fix already so hopefully the full solution will be in Copter-3.4.
Stuart
