Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                • It was a Whitespy compass that I had trouble getting the orientation right with also. It is the only compass that I have used so far that required extra work to get it right.
                  • i suspect all whitespy units are unsafe. 45mm gps unit ate battery i soldered in in fall over winter, and its gps is producing highly erratic data that causes vehicle to wander around. it is not charging battery and i am not going to solder in a replacement anymore. reading of sats also dropped from 18-20 down to 8-11, it correlates to responses from some other people. smaller 35mm unit seems to be getting more stable readings - vehicle is not hunting around that much with it as gps source but it is also reading 12-14 sats top, a m8n unit.
  • Another flight with 3.4 flew great. Just wish I could increase the PIDs but with my Mac and APM P2 I can't :[
    BTW    LASTLOG.TXT = great idea!!! probably been around a year but I only just noticed... excellent idea!!
    • You should have the full parameter list and in there you can adjust PIDs. I would have to look the names, but I'm pretty sure they start with ATC_
      • ahhh yes good point. Thanks
        • Does anyone know of a Website that has the parameter list and what the meanings are ?
          • That's one thing I REALLY like about Tower is if you select a param it actually tells you things about it. My GCS on my computer running APM P2 often just tells you you can select 0-10 or something like that for flight modes. So unless you have that memorized you don't know what to select.
          • Is this the list you are looking for? http://ardupilot.org/copter/docs/parameters.html
            Complete Parameter List — Copter documentation
            • Yes, Thank You Derek
    • why not use bootcamp, or a virtual machine, or maybe wine and use mission planner?
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
