Hello,
I got to the point in my first quad arducopter build where it came time to load the code, exciting!
With everything connected, (including ESCs) I proceeded to power up the board via USB.
The dim LED struck me as kind of odd, but at this point I don't know that what i've just done is a no. So I make 1 attempt to load the code whith no success obviously. That's when I unplugged it.
Upon closer inspection the manual I found it rather casually mentioned here:
"3. Upload the ArduCopter firmware to the APM.
- Plug the board into the USB. If you have ESCs connected to the board, you must also be powering the board via a battery (though the power distribution board if you're using the standard ArduCopter frame). If you do have the ESCs connected to the APM board and you don't power the independently of the USB cable, the code will not load and you may blow your outputs. (You can tell you're overloading your board if your APM LEDs are dim). "
I connected the battery, made a minor correction to my sketch folder name/location and the code loaded fine.
now when I power on the quad the motors beep really fast and nudge just a little....
I calibrated the esc's according to the manual and tested each motor idividually for proper spin direction
Thanks,
Toby
Post script,
in kinderkram's build log, at the bottom (after you fry your outputs)
there is this warning
IMPORTANT WARNING!!!
When you plug in the USB make sure you don't have your ESCs and motors connected.
Otherwise you will blow your outputs!
you guys know the next question.
Why is this warning not in the ArduCopter manual?
Hi! When this is done, would that also affect the inputs of the RC?
When the APM does not have an output, what steps do we need to do to revive it?
Hmm, I did not read the 3 pages, so excuse me and ignore if I am saying something wrong.
I had the same problem several times, disconnecting the battery and forgetting the USB, though I never fried anything because my PC cuts off the power on the USB and I receive a message saying something like : "the USB port is drawing too much power that it can handle. USB port has been cut off, please disconnect blablabla..." maybe because it is a Mac or something, but I guess most PCs have some kind of overdraw protection...
So logically this issue should not be a problem, but there is surely a way to upgrad the APM.
Anyway just my 2 cent
Here is what he wrote:
"As a safety reason, do not keep your battery connected while connecting your USB.
There have been some incidents that people has burn their outputs which still is mystery why. So we gave instruction that not to have battery + usb powers at same time. I personally have been having them many times and no problems but follow wiki pages for safety.
--jani"
What I am trying to figure out is he is telling me NOT to connect both, but follow the Wiki?? The Wiki states to use both?? Great information from one of the leaders! Now I am out $170ish !! You might want to fix the Wiki to represent the PROPER procedures!! You might want to have the Wiki reflect that you should not connect ALL ESC wires to APM! There is NOTHING stating this! How the hell are people supposed to know this stuff?? We look to "the leaders" for support but get the wrong information?? WTF is that all about??
i have some problem power up ESC beep really fast and motor nudge, but hookup USB cable use configurator click send motor command and it work fine disconnect usb cable still ok, but once removed battery, powerup same thing happen again.
is circuit board blow?
thanks
john
~Kaotic
~Kaotic
In case of nay non function to know that is not the problem?
I understand that all functionality is OK , all blinking leds etc. no problem connecting to pc , but the out signal is not working , in case of MUX prob ?
I`m still waiting for my motors and esc, but I connected 2 servos to OUT 4 and 5 with this code.
APM_RC.OutputCh(4, APM_RC.InputCh(6)+(pitch)*1000); // Tilt correction
APM_RC.OutputCh(5, 1500+(roll)*-400); // Roll correction
The servos are receiving electricity when system started , but not responding to the giro etc.
I am not sure how this setup would work with our current ArduCopter config as I don't have my Arducopter fully built yet, but HERE IS A LINK to a XBee wireless programming tutorial that seems like it might be something to look into as a solution to this problem and maybe even add to the WIKI as a required step. (We can add COMPLETELY WIRELESS PROGRAMMING to the ArduCopter feature list!)
I know I would love NOT to have to unlplug my ESC's etc and plug my board in via USB during test flights just because I am an idiot and mis-typed one of my variables, or forgot to uncomment parts of my code!!
Forgive me if this is already posted somewhere in the forum, i haven't quite made it through all of the posts yet
I see it has been added, perhaps there should be a warnings section, listing all the potential-to-fry or potential-to-crash warnings.
