Hi
I am trying to set up a LidarLite sensor from PulsedLight.
I set it up according to the wiki (new sensor, manufactured Feb 2015, interfaced with a Pixhawk)
In the wiki it points to the Flight Data Screen to test the sensor,
but I only get zero as reading in this window.
But if I check in the terminal,
I can see that the sensor is working (see attached file),
so is it working ok? Is the wiki wrong?
Thanks a lot,
Felix
Please note that there might be some problems with the Lidar Lite, more info here:
http://diydrones.com/forum/topics/comparing-lidar-lite-and-sf10-b-i...
It seems that the working range is not "more than 40 meters" as claimed, but more something like "maximum 20 meters" !
More info in the linked thread during next week
Hi All,
Please review my write up for RC4 and LiDAR at Copter-3.3 beta testing. I think there is some useful info I placed there.
Thanks,
Doug Walmsley
Thanks Grant.
Thanks for your replies Grant. I may give it a try.
What's the bottom line on using LidarLite?
Is it reliable and accurate (more than baro and GPS)? Altitude drift from the barometer and/or GPS accuracy issues are causing RTL/Land inaccuracies during descent and flying in general. I've seen this on all my copters of late.
Thanks.
Used in PWM mode yes I believe it is more accurate and better then GPS and baro.
Thanks, Grant.
There are still various issues with the I2C of the LIDAR-Lite (even with the new models, manufactured after Feb 2015) which is the reason why I would recommend you to use PWM.
Felix, Randy has asked me to make the same test as I did with an arduino using pixhawk and I2C. Unfortunately I have no more pixhawks in stock and am ordering new ones. In the meantime if you have time to make these tests, that would be useful for Randy to troubleshoot.
all right - I will try to do the test tomorrow.
But - he would like the LIDAR to be connected via I2C - not PWM?
Cause I didn't manage to get any data in the sonarrange field, using I2C (that was the reason why I started this discussion), due to this I moved to PWM (as well because of the discussion on the internet regarding the I2C of the Lidar still not being safe).
yes indeed via I2C...
2
3
4
5
6
of 10 Next
