Long Range RC Equipment?
I'm looking for some RC equipment for my next UAV. My question is what kind of range will I get out of a basic $100 2.4Ghz system? The Xbee modules work up to 6 miles. Can I get that kind of range with an amplifier or some other solution? Or could I control my plane with the Xbee's?
I appreciate everyone's support!
  • I have had a 1000 meters with good signal strength with 2.4Ghz 60 mW Xbees with my tricopter, all crashes were pilot error not the controller
    Kiwi Tricopter: Arduino Xbee Receiver
  • my futaba 6ex has been out to 1.75 miles easy
  • hi folkz
    you can use the XBEEs in both variants: 2G4 for testing RC-like "in sight" and the longrange 900 or 868XBEE for telemetry and waypointsetting.. works for me up to 5mi but some nasty 10% dutycycle...
    or control when in sight the UAV with classic RCgear or 2G4 XBEE and communicate with a GSMmodem on mission. you can live-track with leonardo, send MMS and SMStelemetry. for me the best way of longrange-UAV. but beware of the LAG ;-) and use a data-flatrate on your mobile!!!
    The FrSky modules have been tested out to about 5km LoS. There are many variables however; your question is too vague for a simple answer.
  • You can use http://store.diydrones.com/ProductDetails.asp?ProductCode=WI-AMP-24...
    without any modification to your 2.4ghz RC system.
    For my long range 2-way serial system I used some 433mhz radio modems. Operation is the same as with Xbee's giving your a two-way serial communications pipe over radio. But range is much better.
    link: http://diydrones.com/profiles/blogs/long-range-rc-control-and
    No Xbees won't operate out to 6 miles, its illegal anyhow. Your RC will probably not work much beyond 500m either.
  • The Xbee modules work up to 6 miles. ?
    Their output's is not so high , i think their range is smaller then 6 miles ?
