Pitch is reversed: where should I fix it?
I was doing the first preliminary tests and was testing to see if everything looked ok.
Throttle, yaw, roll all works fine: if I move the stick the copter moves the way it should.
The one one that is reversed is pitch: with the front arm pointing forward, if I raise the stick, it pitches back (as in, coming toward me), while if I move the stick to the min, it pitches forward (like going away from me).
It looks like it's reversed, but it's weird because the radio configuration on the mission planner said it was ok.
Is there something wrong in the wiring up? I don't think so as apart from this little problem the copter looks like it's behaving correctly. Should I reverse the channel on the radio? or on the mission planner?
Or maybe it is correct that way and it's supposed to work the opposite way I think it should (stick up-raise front arm => pitch back, stick down-raise back arm => pitch forward)?
Thank you
Simone
  • if just reverse on transmitter, does the quad will move in right direction when auto pilot?
    Richard Boyhan said:
    You can just reverse the pitch under radio config in Mission Planner. Whatever feels comfortable to you is correct.
    Richard
    Hi, I was doing the first preliminary tests and was testing to see if everything looked ok. Throttle, yaw, roll all works fine: if I move the stick t…
  • Hello!
    So, your copter was moving towards you in auto mode and you "reversed" the "pitch"? Actually I am having the same problems but I thought that I need to "reverse" the "roll". I have read that on different forums.
    Please reply.
    Simone Chiaretta said:
    I really couldn't live with the idea that I had to reverse the pitch channel to have it working correctly, so I searched around the site for something that could explain it (btw, the google search is much better than the internal search).
    http://diydrones.com/forum/topics/pitch-direction-and-yaw
    Basically it says that it's a bug.
    I created an issue for that: http://code.google.com/p/arducopter/issues/detail?id=531
  • There were a couple of mission planner update a while back that had mysteriously reversed my pitch controls, the next update fixed their error.
  • Thanks for the tip on going to the advanced parameters. It got my pixhawk working clean. The exact advanced parameter is RC2_REV. It has to be switched from 1 to -1 to reverse the channel for pitch. That is if channel 2 is still set to pitch in the transmitter. cheers!
    • Thankyou heaps for this. It fixed my issue aswell. My transmitter does not have reverse function when in multicopter mode so this was the fix i needed.
  • As Rechard told you, the best way to change it is by reversing the stick orientation in the transmitter settings. If you change your wiring, you are gonna have much worse problem with other axis and it will be totally unstable.
    • I know its old post now, but Im having same issue. My Tunigy i10 does not have the reverse option in the transmitter itself when in multicopter mode, so only option is to try do it via the flight controller itself :S
  • I had this same problem. I kind of went into a mild panic and landed hard :-(
  • Interesting, answered this same question in another discussion to day already: http://diydrones.com/forum/topics/reversing-pitch?xg_source=activity
    Mostly same as above though do it at your RC transmitter.
  • Hello all I have the same thing I want to reverse the pitch but can't. It is not longer an option in the mission planner?
    I have a DX7 and thought I have reversed it on that but still does the same thing, so can someone let me know have to change the pitch in the mission planner?
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
14 hours ago
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
