This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens. Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
Thanks Thomas!!
I updated to the latest 3.4 as of today.
Still can't calibrate the ESCs. When armed, nothing happens, no response. With 3.3.4, the motors would go full blast with the slightest addition of throttle.
Uploaded the latest log, hopefully it's the right one because the date and times are all off.
99-12-31_18-10-40.bin
Hi De Le,
It looks like you are using oneshot. Have you tried with normal esc output?
You may want to try loading your pixhawk on the usb power then enabling the output and only then connecting a battery. That will ensure your esc's are getting the shorter pulses straight away.
Yes, I've got PWM enabled now and with 3.4 still nothing. I've tried setting the MOTOR_PWM_TYPE to 0 and 2 and nothing on 3.4
I'm using RCTimer 30a ESCs loaded with the latest BLHeli firmware. Originally I had PWM disabled, then I enabled it but still nothing. With 3.4 I get no tones from the motors when I plug in the battery.
I can throttle up the motor just fine going to the receiver, I was able to throttle up the motor fine on 3.3.4 also... just had no control, it was either off or all the way on. 3.4 has no response what so ever.
as temporary workaround I'd like to offer you an advice:
use blheli/simonk firmware to set all endpoints the same on your ESC, this should be more than enough to fly.
I had all the endpoints setup with the ESCs prior using Cleanflight on a SP F3 racer board. Everything was working fine. I swapped out the board with the Pixracer.
@DeLe, perhaps a silly question, but could it just be that you have the safety enabled? Either set BRD_SAFETYENABLE=0 to disable it or press the safety button to stop it flashing.
My apologies if you already checked this - it is a common issue with people coming from other flight controllers that don't have a safety switch.
It's already set to 0. I originally had the switch but then removed it as I saw that BRD_SAFTYENABLE was 0
47
48
49
50
51
of 110 Next
