Hi guys,
here is a rendering of the printed wing I have been designing. My idea is to create a rapid prototype/carbon fibre composite material which I can use in UAV applications. The concept is to be able to print the RP parts directly from CAD data and then cover in carbon fibre pre-preg. The use of RP allows quick design changes and iterations without tooling. The RP is used in the same way a structural foam would be used.This concept is for a UAV around the 20kg weight size, I'm not sure it would be possible to make it light enough for smaller UAV applications.........
I am hoping to produce the physical parts in the next few days. Part of the callenge is to create a lightweight structure that will build easily on the RP machines and something which will skin up ok in CF. I may need to do a couple of iterations before it is acceptable.
I'll post some pictures of the finished parts as soon as I have them....
Happy flying!
Oliver
I have similar idea, and fill it with styrofoam. But if You intend to use it in drones those cuboids (I thinlk) will be to strong
I have spent some time analysing construction methods for the wings of my HDwing glider concepts and so far nothing can beat a fully balsa skinned, balsa structure wing for weight and stiffness, unless you're trying for some impossibly ultra thin aerofoil. Even a CF skin on its own made unmanufacturably thin is still heavier than a fully structured built-up balsa-skinned wing in my application.
Larger structures may close the gap, but I'll bet balsa will always take some beatng
Adding die-pultruded wet carbon filament spar caps can add a a lot of CF-style stiffness for very low weight (and cost)
For the honeycomb areas, it would be possible to use laser cut parts to come to very near the same design. Then you could choose from sheet foams like depron, styrene sheet, woods, balsa, lite ply... Could keep costs down and allow enough weight savings to allow other design changes, like sheeting under the skin.
It was mentioned above as well, what material does your RP use? Can it handle the curing temps and pressures?
Have you done any FEA with the core 45° off current?
When using prepreg is a high vaccum needed during cure?(I'm not a composites guy)
Maybe a spool gun for aluminum welding could be modified to lay individual carbon fibers?
Also did you look at a 4 axis hot wire? you would be able to cut most wing shapes untill you start to go eliptical or something like that. I know at Madison we were able to have a few test cores cut for us and the place that did it normaly cut foam for chairs.
Small minor note looking at your model you would like to bond you spar to your skin. this will add some weard forces to your spar but if you are buying your spar it will most likely be stronger than your skin and haveing a good way to directly transfer the force from the skin to the spar would help. Or you could glue your spar in but that costs weight.
How thick are those honeycomb wall? Can you make them 3mm thick?
How big of a panel can you make?
I just found this thread and it looks really awesome. By the way, I dont think you will need a spar as those honeycomb pockets will be more than enough, especially if the skin is carbon.
