Hi everyone,
I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery: 4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
Latest Toy----
frame:KK MK X525 goodluckbuy.com $29 !!
controller/autopilot: APM2
motors: 880kv
esc: 30 Amp goodluckbuy.com $ 37 /4
propellers: 12x4.5
battery: 3300 ma 3s
radio: Spektrum DX7
I was very happy to get this frame at $42, and now that they are blowing them out at $29 (free shipping)!!! I have to say this is the best buy in the business. They are very strong with properly designed spring loaded legs (this will save more damage than you can imagine).
The only flaw it the motor mount they supply - very flimsy, tends to vibrate a lot. I used 1/8"x3/4" aluminum to make new ones, and now the unit is extremely smooth and vibration free. I have had almost no flight time yet but so far it looks smooth with Stab_D =.06, R/P D =0, R/p P=.1
frame: Custom CF 820 x 820 @ 1200 grams with bat, gopro and custom gimble and unbreakable (posibly) !
motors: Turnigy 3010c (1300kv)
esc: Turnigy Trust 55A
propellers: 12x5 or Tri 9x4
battery: 22.2v 2300mah (6 cell)
flying time:7 mins
radio: Futaba 8
video/osd: Gopro
other: Can lift 1.5 extra Kilos for 6 mins
Misc (hacks/mods): not quite tuned yet but is stable.
Could everybody please leave there config files or there Pids so that we can compare (and copy).
photos:
quad 010112.param
How are your motors doing with that voltage? HobbyKing quotes that as a 3S motor, and from the little I've gleaned from the Gordian enigma that is motors/props/batteries, lower voltage draws more current making more torque.
I tried running 2836 1100kv motors on 4S with 11x4.7 props and the motors could fry bacon, so that's not working. I'm still trying to figure out what the factors are in turning a prop!
My X8 Quad specs
Board: AMP1
GCS: MP1.1.31
Firmware: 2.3
Quad X8 (coaxial 2 motors/ESC per arm sharing one APM signal)
3300mAh 4S 35-70C
Droidworx ADR Quad Standard, (72cmx72cm across)
Flight weight 2.4kgs
Motors 880kv Jdrones
8 Props 12x4.5
ESC 30A Jdrones
APM power supply. 5V, 3amp switching regulator (SVR3 Tahmazo)
Sonar XL-EZ0 (MB1200)
Declination: -0.5899
frame: Gaui 330x extended frame
motors: Arrowwind 2250/15
esc: Feigao 18-Amp
propellers: Stock gaui
battery: 2800mAh 3S
flying time: 7min (with a big safety margin)
radio: Futaba 10C / orange 8Ch RX
video/osd: GoPro HDhero no FPV (yet)
other: Pololu RC switch to LED lighting
Misc (hacks/mods): extended frame, wide skid set
ArduCopter Heavy Octo X8, here the related thread:
http://diydrones.com/forum/topics/arducopter-heavy-x-octo-fw-2-0-56...
Bests
Marco
My latest frame, named Firefly Mark One, is a 3D printed multirotor. See the flight video in my blog.
Here's BoM for major components used:
4 x FC 28-22 Brushless Outrunner 1200kv $6.99 each
I'll start off..
frame: My own hexa creation
motors: 2836 880kv (3DRobotics)
esc: 25A (Turnigy Basic)
propellers: 12x47, (Found a distributor and order 30 at a time)
battery: 3S 5000mAh (Turnigy nano-tech--45-90C... 6 motors draw way more amps..I messed up my 3S 6000 25-50C pack) flying time: ~9Min. 9 Min Flight
radio: Turnigy 9X
video/osd: GoPro/none other: Sonar, Xbee, GPS/Mag,
Misc:
