Hi everyone,
I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery: 4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
Hi Group,
I admit, I am a new and a complete novice re RC and UAV, drones et al.
Reading a lot about drones, following all the internet discussions
and rc groups, I finally committed myself :)
I am technically/electronic-minded-abled person though :)
Herewith a summary of my components I have selected for my Quad Build
Air Frame : Tarot 650 Sport with Electric Landing Gear
Motor : Tarot 4114 KV320
ESC : HobbyWing Xrotor 40A
Prop : 15.55" Foxtec Brand
FC : Pixhawk (incl GPS, minimOSD, 433 telem etc)
Radio : FrSky X9D + (Taranis) > Mode 2 Receiver : X8R
Gimbal : X-CAM 3-AX
Cam 1 : FHD Tube cam for FPV
Cam 2 : GoPro Silver 4 recording
Vid TX : 5.8Ghz 600mW
Ground Station : Diversity 7" with DVR function
Batt : 6S 8000 25C >> Zippy, Gens Ace, Tattu, Turnigy nano ?? Any good??
(Power Module can handle up 30Vin,
with the corresponding V/I monitor values to interface with the PixHawk)
Application : Aerial Vid/Photo hobby interest
I will post pics once constructed.
On completing the construction,
I want to venture into configuring the X9D for the Quad.
Prior to doing any Flight configurations with the X9D,
my first attempt will be to configure the X9D to operate the Electric Landing Gear (ELG)
To boost my confidence?? :)
My thinking here is >>
To configure the X9D to operate the ELG,
I assume one select a switch eg SF, which is On/Off operation
opposed to SH which is Momentary?
(Or should one use a Momentary >SH< for ELG operation, I think not)
iow > using SF in one direction ELG retract (for flying), SF in other position ELG extend (for landing)
How do one configure that on the X9D, assuming assigning CH8 on X8R rcvr for ELG operation?
If someone has done likewise and is prepared to share their knowledge, I will appreciate it.
I have looked at many build-vids/how-to vids/ to broadening my knowledge,
to date I have been unable to find info to help me implement this basic function.
Any vid-links etc that you can point to will help me, I think.....
I realize with this question it shows my novice approach and newby status,
BUT if I can configure the X9D to perform this elementary Function,
see the ELG operating, it will put a BIG smile on my old whaSog!!....
Thank you once again for your valuable and knowledgable feedback.
Gerhard
I don't have that radio but here you can see my Tarot if you want to take ideas http://diydrones.com/forum/topics/my-second-cuad-a-tarot-650 I'm not an expert but if I can help with another thing, I do it ;)
I've been interested in building drones and RC in general since Xmas 2014 when I got a tiny Cheerson CX-10 bought for me as a present. Well, I'm a bit obsessive when it comes to new hobbies, so I ended up doing a lot of studdying on the forums, and built my first drone. It was a:
Looked like this initially:
I soon learned that the Turnigy Plush ESCs flashed with BLHeli v12 didn't play well with Pixhawk (it was really random on power up which ESCs would actually initialise - due to new bootloader code in BLHeli), so I switched the ESCs for X-Rotor 25a and it flew quite well with no apparent issues.
Then I crashed! It was actually due to the PosHold doing a flakey and the copter deciding to go off flying by itself in a seemingly random direction! I tried to take control but not before it hit the deck and smasked my landing gear and the fibreglass mounts I had built to retrofit the gear to the F550 frame. So then came a new design idea!
I decided to build on an extra deck to the underside of the quad which would act as both a battery tray for 2x lipos, plus the landing gear mounts. This is what I ended up building:
Much tidier job, but within 2 weeks the gibmal went faulty - still waiting for HK to replace it!
Anyway, the hexa flies really well. Its final build spec is this:
Some pics of final build:
After I finished this, I realy got the build bug! I started on my latest build a Tarot 680Pro. That will be another post!
Edit - I finished the tarot build and really this F550 is sitting gathering dust now, so I'm thinking about selling it. Get in touch if you want further info. Even though I have borrowed the telemetry radios from this hexa for the tarot, I have another set on order so it will be sold with 415Mhz telem radios plus the 4 x LiPos mentioned in the list above. The only thing it won't be sold with is the gimbal and associated electronics.
Here is mine:
FRAME: S500 Glass Fiber Quadcopter Frame 480mm - Integrated PCB Version - Weight
FC: HKPilot Mega 2.7 Master Set
ESC: Q Brain 4x25A Brushless Quadcopter ESC 2-4S 3A SBEC
MOTORS: Turngiy D2836/8 1100KV
PROPS: 10x4.5 SF
BATTERY: Multistar 3S 5200 Mah
TOTAL WEIGHT: 1780g.
FLYING TIME: 7 minutes fully loaded.
RADIO: Turnigy 9XR (with FrSky DF Combo for JR) - Modified as a ground station - See video here :)
VIDEO: SJ4000 + SkyZone TS353 5.8Ghz 400mW FPV Transmitter + SkyZone RC805 -5.8Ghz 8 Channel Receiver + MinimOSD
GIMBAL: 2 axis e-bay gimbal (planing to upgrade to 3 axis goodluckbuy gimbal with storm32 board)
RECORDINGS:
9XR RADIO AS GROUND STATION
FLYING FROM OUTSIDE:
PICTURES:
Happy flying to everyone :)
AlbEagle
Hi
Strayed from the DIY approach and decided to buy a frame. This is the Aeroxcraft 670 quadcopter which is very sturdy and fairly light.
DJI Naza v1 flight controller with GPS
Turnigy plush 30a esc
Eflite 480 motors
HQ 11inch props (very good props)
3s 6000mah lipo (10+ mins flight time)
Quanum Q-3d gimbal with Gopro 3+
I will most likely migrate naza v2 equipment from my scratchbuilt hexacopter into this frame since I prefer its flight
characteristics.
Hello everyone. Newish to this site, been the creepy troll reading all about quads and UAV's etc on this site of awsomeness.
Here is my current quad, tis nothing special. Using this frame because I may have broke the PVC setup I had.
Here's the specs:
Motors: DJI 2212 920kv
Props: Generic 1045 carbon fiber (amazon)
ESC: Generic 20a w/ simonk
Frame: HK Q450 V3 (DJI Knockoff)(very good frame for learning to fly. Actually crashed it and and it rolled across the field like a wheel.)
Flight Control: CC3D (don't judge)
Battery: Turnigy NanoTech 2200 3s 20c
Transmitter: Turnigy 9X v2 flashed with Open 9x and backlight. This made a pretty annoying controller into an extremely useable one. (no smarty parts, was brave and soldered the wires)
Current build (#2) is a wood hex 550 using pretty much the same hardware except it will have APM 2.6 clone onboard, as I wanted to go more autonomous flight to do fly throughs of completed construction projects. I plan on giving the booms a 4º incline for dihedral for more stability. Yes, probably overkill for flying a go pro around, but I have to convince my wife its not just another toy =)
Nice Setup, what is the flight time ?
It is based on the Armattan FPV v2 TILT frame, about of 350g. 'Tilt' part of the frame was ignored and replaced with a gimbal. Whole frame is a multi-plate carbon fiber construct that is able to survive a nuclear blast, if needed.
Inner frame cage part is mounted on 6 rubber bobbins and vibration isolated, FC sits on additional vibration isolation pad - was probably an overkill but works fine. Total cost of all parts in this pictured setup was under $500 including battery and GoPro, as that was the point - to see what can be done using cheapest parts available on Ebay and a solid indestructible frame.
Propulsion - DJI old red 2212 980kV motors, Mystic SimonK 30A Black ESCs, 9047 props, 5000mAh Turnigy 20C battery.
FC - APM 2.8, GPS/Compass - M8N, Taranis X8R receiver, Teensy 3.1 board for telemetry into X8R.3DR radio telemetry transmitter.
Simple cheap $40 gimbal from Ebay, GoPro 3 White, Boscam TS351.
MinimOSD was taken out due to extreme glitchiness and a practical lack of purpose.
Total armed weight of the build - 1810g, flight time with all systems powered up and GoPro filming - 15m20sec until battery goes to 3.5V per cell from 4.20v initial charge.
i'm currently using APM v2.6 for my quadcopter. i have set the flight mode to stabalize and i powered up the copter. i was also able to arm the board (and the motors started to spin). but later even for the full throttle the copter is not able to take off the ground. i kindly request someone on this forum to help me out to fix this issue. plzzzzzzzzzzzzzzzzz
thank you
