Share your drone info thread
Hi everyone,
I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery:  4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
3690911422?profile=original
3690911286?profile=original
3690911495?profile=original
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
    • 3702585170?profile=originalKids, Math Matters... So I got my parts in and got her assembled. Jumps off of the ground at about 40% throttle, and very gently flew for a little over 30 minutes before I got worried the low battery alarm wasn't working. Tested it and the 5200mAh S3 battery still read 10.8 v (Wow 15min would have done). Considered going back to flying but the stress of a fresh $1000 CND ( about $650 US right now) floating around was getting to me. I spent a weak of working out pitch/size/thrust/efficiency/weight putting this together. Sent the Teleporter back before I even opened it, QVGA is too low (Have OSD), Predator V2 are coming in the mail. Took Scott Messe's advice and order some smaller batteries as this thing is a mini tank, Excited to go exploring in FPV shortly.
      • So realizing that this hobby was going to be taxing my paychecks anyways, I purchased a 3D printer to save in the long run. 2 More drones using the same hardware as above, but with a battery tray designed to use either a 2200mAh Li-Po or a 5200mAh Li-Po, depending on if I want long flight or fast flight.
        3702720441?profile=original
        • Hi Matthew,
          Personal interest, which 3d printer did you buy and what is your experience in using it?
          What products have you printed sofar?
          I am interested in buy a 3D printer myself,
          so when I see comments e 3D printers, I try to find
          out more info from the 'man in the street'.
          Thanks for sharing!
          Regards
          gG
          • I'm Using a Print-Rite, $300 USD from hobbyking.com 210x210 non headed print bed. I do my modelling in Blender, (1 BU (Blender Unit) = 1mm). I slice using an upgraded version of the supplied Repieter-Host software. It's been fantastic once you figure out settings. Best print results are at 4mm for the first layer, then 2mm for the rest, but supports 1-4mm layers. Parts are strong.
            3702851146?profile=original3702851291?profile=original3702851364?profile=original3702851421?profile=original
        • 3702799215?profile=original3702799070?profile=original3702799185?profile=original
      • R.I.P. Mini Drone. At about 600 meters she started to oscillate then went into an uncontrollable free fall. I think one of the carbon fiber props either came apart or became unbalanced. Damage: Video transmitter, FPV camera lens, 3 props, screen on Emerson action cam, both wings, and battery. Worst part, Camera lost its recording... :-(  Next build, Hex or Octo-X with motor failsafe.
        3702713548?profile=original
        • The crash was caused due to the fact I didn't factory reset my Naze32 before using it. Everyone using the great Naze32, factory reset it before first use. Some of them have an odd bug fixed by resetting them when shipped.
    • That battery will most likely be too heavy. I get about 15min flight time on my 450 quad, but it is super sluggish just due to the weight, but only use it when the camera is on it. May also not fit the frame as the specs state a much smaller battery. Typical battery I run on my 450 is a 3s 2200mah and I still get 12 minutes or more out of it.
      • Yah, that's kind of my biggest fear. The battery will be strapped to the bottom instead of the landing gear, so size really isn't as big an issue as weight. All up weight should be 730g, and my calculated max thrust should be close 1600g (Hoping), but I think I will grab a smaller battery for fast flight. Do you recommend any particular brands?
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
