Hello Folks:-)
I have a big problem to get the Pixhawk running with my Taranis plus and the X8R receiver.
Here I already posted the Issue.
What I have:
Taranis Plus with Firmware 2.0.17 and latest internal XJT non_EU update.
X8R Frsky Rx also with latest non_EU update.
3DR Pixhawk and a clone from belize
Arducopter 3.3-rc7 (also test 3.2.1)
What I did:
I flew many hours with my small grasshopper 250 very well with my old Futaba with Jeti TX system. The Jeti Rx has a CPPM out. The System is stable in all phases and all Modes.
Now I want to give my Taranis plus a try which I bought in 12/2014. So connected the X8R SBUS direct to the RCin from the Pixhawk and calibrated the Radio in Missionplaner with no problem.
The Issue:
The Copter flies, with the FrSky system, in stabilize as usual and very good. As soon the Mode changed to Alt.hold, Pos.hold or RTL the copter get some wobbling or unstable attitude if a interference coming up. The interference can come from a gust, or a RC input. Special when switch in Autotune the Copter become very unstable, sometime he fall out of the Sky.
Once it was possible to complete the Autotune in roll and it gives me a PID from P=0.01;I=0.01!!
I also switched off the Tx during a fast forward flight, as the RTL command came the copter wobbles very heavy, which It not does with the Jeti Rx!
What I tried to solve:
Changed old to new Firmwares on the Rx,Tx and Pixhawk,
Tried another Pixhawk, another Rx and a D4R-2.
Changed the PID in a lot of direction (I´ve experiences in tuning PID´s)
Changed in between, with exact the same setup, to my old Futaba/Jeti system without any Issue!
I've setup the system from the scratch, several times.
Bind the Tx/Rx in differend modes several times.
Had a look on the sbus out with a Oscilloscope to check the Signal.
Now I´m at the end of my knowledge and need help from the Forum to figure out the problem.
I´ve seen that the sbus signal goes to another input of the STM32F100C8T6B (IO CPU) in the Pixhawk. So maybe the Firmware of that CPU has a bug. Does the IO CPU will be update with the Firmware from the Missionplaner, or is in the STM32F100C8T6B a fixe Firmware?
I know the beaver is strange and unbelievable but true!
May be there is someone from Germany who has the same setup and like to help me personal.
All constructive inputs are welcome!
the test Copter:
Now I can confirm the Issue!
With a second Taranis I had the same issue but only in my flying Area!
After flashing the XJT Tx and the Rx with the new eu-Firmware the problem was solved!
I guess I could find the Problem!
In my Flying area are to many 2,4Ghz devices that course the interferences, even when the RX is off and the Copter fly Automission or RTL.
I flashed the XJT and the Receiver with the new EU-Firmware! But still I've to fulfill more test to be sure.
Thanks for all the hints!
Yes, foam over the baro! I´m always swap between Jeti and Taranis to see the different
Today I finished my Alien560 Copter.
There is more place for all the Items. Just for testing I separate Radio/Rx from GPS/Compass.
But unfortunately I have the Same Issue! After switching in Autotune the Copter crash.
With the Jeti system I've no Issue withe the same setup!
here the log
and the Pic of the testing Copter
It will help your RSSI to move your antennae to be at 90 degrees with one on its flat side and the other on its edge... (See pic) It will probably not help your issue though... I have the same setup running same FW and all is good. Sorry to hear you are still having problems.
But then it would have the same behavior with the Jeti TX/RX, right? This is not the case
I don´t have a Camera
Your setup must have something special because 99% of the people on this forum fly with a taranis,x8r and a Pixhawk without issues. Are you sure you connect the CPPM servo cable at the right ports of your receiver and Pixhawk? How is the receiver powered? How is Pixhawk powered?
"Are you sure you connect the CPPM servo cable at the right ports of your receiver and Pixhawk? How is the receiver powered? How is Pixhawk powered?"
with CPPM you mean the SBUS from the X8R? Yes sure it is correct connected to the RCin port of the Pixhawk. As I wrote above, the RC channels are working!
The Pixhawk is powered with a 3dr Powermodule and 2nd with a 2A BEC on the RC side!
Zero issue with the same hardware, check your wiring and the component position.
1
2
of 2 Next
