Here are some Photos showing how to get 6 positions on a Futaba 9C super
It will set them for these 2 switches
go to advanced settings choose PMX-6 CRV
first page 1/2 of PMX-6 CRV  should be set as shown below
Second page 2/2 of PMX-6 CRV should be set like this (below)
Make sure to note the order in the planner when setting up your flight modes, the switching order is not 1-6 in order.
that should do it,
Comment by Michael Krader on December 29, 2012 at 10:28pm
thank you very much.
Comment by Luis Ramos on December 30, 2012 at 10:25am
So with this setup you only have programed switch D .....how you switch true all the 6 positions with it???
Comment by Aaron Henry on December 30, 2012 at 11:19am
Switch C has 3 positions X 2 positions of switch D gives you a total of 6 combinations.
Comment by Luis Ramos on December 30, 2012 at 11:23am
Ok got it!! Thanks, i will try it.
Comment by Eric Thomas on January 19, 2013 at 1:28am
One thing not mentioned is you need to have channel 5 configured to switch 'C'.  Using the curve mix is definitely a good idea; here's what I ended up with:
  AUX-CH CH5=>Sw-C
  Mix PMX-6 CRV
    MAS=>5, SLV=>5, LINK=>ON, SW=>D, POSI=>DOWN
    POS 1=>-63%, (2=>-40%), 3=>-22%, (4=>+10%), 5=>+49%
      (position 2 and 4 have no effect)
Comment by Eric Thomas on January 19, 2013 at 11:33pm
Update:  With the above settings I had endpoints setup on CH5/GEAR of 80%/80%.  With CH5/GEAR endpoints at 100%/100%, here are my settings:
  AUX-CH CH5=>Sw-C
  Mix PMX-6 CRV
    POS 1=>-71%, (2=>-40%), 3=>-17%, (4=>+10%), 5=>+59%
Comment by Calvin R. Walker on March 16, 2013 at 8:17pm
I follow what you said, but it looks like only positions 1, 3, and 6 are effected.  When I move both switches, the other locations are not highlighted.
Comment by nubli hashim on April 9, 2013 at 10:48pm
same thing goes to me only position 1,3,6 highlighted, 2,4 not working, wonder why
Comment by Fred Flores on April 11, 2013 at 9:06pm
I wonder if this is for a 9C super 72Mhz, I converted mine to 2.4Mhz using the module. I only get the 3 modes too. Does this matter I wonder. Maybe I'll give Futaba a call and see if they can help.
Comment by nubli hashim on April 13, 2013 at 4:46am
ok guys. I got the solution. Follow Eric Thomas setting. exactly.
here's how I do it.::
Firstly go to ordinary screen. push left top button to enter programming. go to page 2/2. set aux channel 5 to switch C. then push bottom left button to confirm
Secondly. go advance programming. push top left button. and choose prog-mix 6.
Then on page 2: set master channel 5, slv channel 5, link on, switch D, pos down
Then back to page 1: set curve 1=-71 curve 2=-40 curve 3=-17 curve 4=+10 curve 5=+59
confirm by left bottom button.
then link to MP through usb, or telemetry and go to config, set th mode. we will get 5 position, 6th is set to manual. push both switch C and D to see which is which mode and change accordingly
there we go
Comment
