APM 2.0 is the culmination of almost a year of hard work. We wanted to make it perfect and we finally have it, we are pushing the limits of AVR and Arduino. I’m sure you will love it, and it’s designed to cover all the DIY community expectations (including those that are not so DIY and are only interested for something that doesn’t require soldering skills).
Check the product listing for availability status!
Main Features
- Three processors--a triple-core autopilot!
- All new state-of-the-art sensors; the first autopilot to use the Invensense 6DoF MPU-6000
- Smaller, lighter, cheaper than APM 1.0--just $199 ready to fly, with GPS, magnetometer and dataflash included.
- Like APM 1.0, this is the world's only Universal Autopilot. The same hardware can autonomously control planes, multicopters, regular helicopters, rovers, even boats, with just a one-click firmware change--no programming required! Best-of-breed mission planning and two-way telemetry, and soon with advanced scripting with Python for robot acrobatics and more.
- Twice as much dataflash memory, with SD card slot
- No soldering required
- When using the internal sensor fusion processor of the MPU-6000, more than half of the Atmega2560 processing capacity is free for new advanced features.
- Native USB, with all new PPM encoder software
New sensors
The big advance in APM 2.0 is the introduction of the Invensense MPU-6000 sensors, which have an internal Digital Motion Processor (DMP) that does advanced sensor fusion. We’ve tested it for months, including lots of flying, and it significantly outperforms the DCM used in APM 1.0. It’s your choice whether you want to use the MPU-6000 internal sensor fusion or do it yourself in the main processor, but if you choose the DMP it frees up nearly 40% of the processing power in the Atmega 2560. This is a digital chip, so we were able to eliminate the ADC chip used in APM 1.0, lowering chip count along with cost and size.
We’ve also upgraded the barometric pressure sensor to the MEAS MS5011, which has a resolution of 10cm! This is at least twice as accurate as the pressure sensor on APM 1.0 and should give ArduCopter best-of-class altitude hold capability. Here are some of our side by side tests conducted by Jose Julio (Spain):
We joke about the color of APM 2.0, we say that is the fusion of ArduPilotMega V1.x (Red board) and the Oilpan/Sensor Shield (Blue board) and resulted to be a purple board. Well this might not be the real reason of the purple color, in fact the APM 2.0 fuses the APM 1.0 and the Oilpan/Sensor board into one, in order to save space and make it cheaper.
Micro daughterboard
But why does it have a small daughterboard with an SD slot, GPS and the magnetometer on top? Aha! The big dilemma I had for months! I was very concerned about leaving the GPS and the Compass stacked on the main board. What will happen to the compass if the board is placed near to big electromagnetic fields like a brushless motor? What will happen if the board is inside a carbon fiber frame and GPS reception is blocked? But what happen if none of those issues matters to you and you want a small board with everything on it? What can I do to solve the necessities of everybody?
So I developed a small shield that can be mounted inside the boundaries of the pins and has special connectors to keep a very low profile of the system, so if you want a small board then you have it! But this shield is optional, so you can still attach your old GPS by using the standard APM V1.0 GPS connector or the classic compass port. But because I promised no soldering I have created a special I2C port (similar to the GPS) that allows you to attach an official APM 2.0 Compass board by just plugging it (yeah just plug and play). The SD slot is there because I had no other place with easy access (underneath the main board was messy and you will be obligated to dismount and flip the entire board to remove the card, you don’t want that right?). In the other hand the daughter board will come in four flavors: GPS+MAG+SD, GPS+SD, MAG+SD and SD. For example if you want to attach only the magnetometer (Compass) externally you just buy the option GPS+SD.
SD card dataflash
The SD slot can read regular SD cards. But for the moment we don’t use them in ArduPlane or Arducopter code because writing regular FAT tables is very slow and can screw up the main loop refresh rate (We’re not using a RTOS yet, and won’t until we migrate to ARM in Q1 next year). There’s why I have created a custom SD card with dataflash on it (twice the capacity of the one in APM 1.0), plus it has the advantage of being removable so you can have multiple logs or you can easily replace it when you exceed the life of the chip. But in case you are planning to use APM 2.0 in something that doesn’t require a 200Hz loops (like a very powerful data logger or weather station) you can interface with a regular SD cards and write text files on them. The possibilities are endless!
The board itself is our first four-layer design and is smaller than APM 1.0 (believe it or not it’s just 2.6 x 1.6 inches, even smaller than the UDB) and this includes four mounting holes and rounded edges to give a nicer look and feel! Of course it’s lead free and ROHS complaint.
New PPM encoder and USB interface
Along with the Atmega2560, there is an Atmega32-U2 that works as the USB (FTDI) serial programmer (Arduino Compatible) and PPM Encoder. This setup allowed us to save even more space and reduce prices by eliminating the FTDI chip in the APM 1.0 board. Best of all, you can update the Atmega32-U2 firmware without buying a SPI programmer; you can easily update via USB!
The Atmega32-U2 also features something called “Serial0 Auto Switch”. This function automatically toggles the serial port 0 from the Atmega2560 from the USB Serial programmer and the modem/OSD port. When you are about to upload a new code through the mission planner or Arduino the Atmega32-U2 will auto-route the Serial0 to the USB Com port and load the code, when is done it will automatically switch it back to the Modem or OSD port. This maximize the usage of this serial port that before was wasted the average of the time (not used while flying). On the APM 1.0 the modem won’t work when is programming and you don’t program anything while you are flying so theirs is virtually no downsides in normal operations. Anyway in case you want a dedicated UART for each you can still switch back to the old APM 1.0 configuration with some solder jumpers.
More I/O
APM 2.0 is also packed with 12 analog pins that can be used as digital I/O pins and three of them can be “solder jumpered” to add extra PWM output channels (for gimbal operations). Each analog/digital pins can be used to read or control special devices like current, RPM, voltage and ultrasonic sensors and output devices like cameras and relay’s. The mission planner will allow you to define in which pins you have connected a device and a drop box will give you the options to select pre-defined sensors or declare a new one (Something similar to Remzibi OSD). This sensors or output devices can be later used in missions and do actions when certain conditions are met (Not implemented yet).
APM 2.0 features 8 PWM outputs (and can be increased to 11 if you give up 3 of your 12 analogs) and 8 PWM inputs. You can also bypass one of the pins with a solder jumper to insert your own PPM signal, still you can use the other PWM inputs left to control something else (so you can have more than 8 inputs).
The +5V servo power is optionally separated from the rest of the board, you can join both powers by insert a regular jumpers. This saves us a lot of problem in some setups. It also features a protection diode to protect the board from reverse polarities. Reset pins are left exposed with ground, so you can add an external reset switch if you wish.
Thanks to the incredible work of the DIY Drones Dev Team, the ArduPlane and ArduCopter code will support the APM 2.0 board when it ships. Special thanks to Pat Hickey, an embedded programmer rock-star, who led the team who ported the code to the new board. Others who worked tirelessly on this include Jose Julio, Andrew Tridgell, Doug Weibel., Randy MacKay, Jason Short, John Arne Birkeland, Olivier Adler, Sandro Benigno, Max Levine the 3DRobotics team and scores of others. It was a huge job!
Special thanks to Chris Anderson for making this possible.
The new code is already in the repository and supports both APM 1.0 and APM 2.0. The Mission Planner will autodetect your board and load the appropriate code (Note: the official 3D Robotics APM 2.0 board has a unique signature and the MP will look for that. Other people can make their own APM 2.0 boards, but the official MP will probably not support them). But if you want to do it manually in Arduino just change this line in Config.h from APM1 to APM2: # define CONFIG_APM_HARDWARE APM_HARDWARE_APM1
APM 1.0 (back) vs APM 2.0 (front)
Price
As you can see the board is more than great! But when you discover the prices you will be double amazed:
APM 2.0 + Daughter board (with all sensors) + 1 x dataflash Card for datalogging + USB micro cable + All pre-soldered and tested for just $399… But we have a special DIYDrones promotion; if you buy it within the next 100 years you only will pay $199.95 (yeah you read it right $199 US Dollars). =P
Seriously. $199 for everything, for everyone, always.
Important note: The board is already available and tested, but with this incredible price you can expect a very high demand (even before formal announcement) so the only way you will be able to get one board soon is by pre-order at the link below. The expected waiting time is from 1 to 6 weeks. First come, first served. We expect to end this delay by February when the shortage of some sensors is over. (We’re going to limit the first batches of board to users; unfortunately we can’t allow distributor sales until customer pre-orders are filled)
Congratulations Eagle, I have less to receive my coveted post.
@ Sgt Ric First I never said it was all about money Sgt. I even gave non profit examples. But as this question was focused on that aspect I made most of my comments directed regarding that. I even said I have supported open source projects and by that I meant non commercial ones.
As for the other answer to DaveyWavey. I really don't get you question then, because I don't get you point about how and ID limits anything functional with or without it, other than support. So the question relates to something completely outside of this here and is just hypothetical. open source as you found out is about disclosure. beyond that there are lots of variables but basically if something isn't disclosed then just that none diclosed item is closed source, not necessarily does it now make the whole thing closed source. As I said in one place. You can add closed source to an open source project/product if you want as long as the open source part you used is disclosed. Support has nothing todo with open source. Open Source has to do with disclosure. So for software it is the source code and hardware the schematics and embedded code. So for a 100% open source you would include where the ID# is placed and how. It doesn't however entitled someone to bypass it's intent in order to duplicate the ID#'s to institute fraud on anyone. So if the ID# allows someone to use it to get support they aren't entitled to then obviously it is fraud. I think the other part of this I answered already or are obvious already. What you are confusing here are serial numbers that are part of a closed authentication system used to activate and or turn on functions. Like microsoft. That isn't what this is about at all and I fail to see it's relevance to anything here.
I don't think the concept of "clone" fits in open source. Everyone make boards of the same open source specifications, so in a way even 3DR are making clones. But every company makes certain design decision governed by their desired profit margin. A company may decide to use cheaper components, which though meet a lower tolerance is still fine for hobby use, which allows them to make a higher profit or a lower priced board. This is why it's only fair that they don't mislead consumers into thinking they are buying another board, which ma
y have higher spec than theirs. Consumers need to be able to make that distinction.
hmm so bottom line is those guys at CUAV should explicitly state that they are clone and their boards should/ could also work with apm planner...
Must put in my two cents. Open source or closed source makes no difference. A product must make money in order to survive. No one will sell a product of a lower cost than production, and survive to continue making new and better products. Open source is not a charity movement.
Aside from the profit issue, there's also the concept of fairness. Open source IS all about fair use. It's not about being a parasite. If someone or a group decides to create a product out of their own hard work, it is unfair for a company to capitalize on this for their profit, without either adding value to the product or in some way compensating the originator in some form, be it monetary or otherwise.
I just recently joined the Dev Team for AC, I don't expect monetary compensation. My motivation is to see some of my ideas being adopted, and to have some degree of control over the software that goes into my quad. I've also been a programmer for 20 years, and love it.
I think at the end Open Source is about fairness, not profit versus non-profit.
I will repeat once again, I think it's unfair, and misleading for CUAV to use the same coloured board, and use images created by 3DR to promote a clone board, that they're selling for a higher price, without acknowledging that the images doe not represent the boards that they are actually selling.
Of course if CUAV was playing completely, by the Open Source model, they'd either have someone helping us on the Dev Team or make enhancements to software that are contributed back to the community.
@Terry, to say that "Open source is all about making profit..." is completely wrong! You completely misunderstand the open source movement to say that.
Making a profit off open source is still possible, but it is certainly not the reason open source exists in the first place!
3DR manufactured APM boards have an ID identifier that provides specfic functionality with APM planner. Whats the difference between that ID number and a serial number for a closed source product? Without it therei is limited functionality, yet when I downloac Apahe, i get the full deal.
Im not being argumentative, and Im sure the ID is for support purposes, but if it impacts other's ability to make their own clone, non profit, not called APM board, with the same functionality , how is APM open source hardware?
"In production and development, open source is a philosophy,[1][2] or pragmatic methodology[2] that promotes free redistribution and access to an end product's design and implementation"
Oh I forgot an important statement. Open source is all about making profit based on adding some form of enhancement or support to the creation. Something as simple as gathering up all the files for something and adding value by organizing it and putting it on a CD has been a long time way of making money off open source. But it has also been true that it is about how much. $10-$20 has always been the acceptable limit. But not doing that and claiming a unique piece of software and then selling it for $350, whether renaming it or not. Same goes for not making available the source.
If I offer an open source product to the world but the product they make from my open source information is limited in some way (even just a little bit) is it open source?
If the only way to get full functionality is to but the board from me, is it open source?
Yes,no,maybe......
