ArduCopter 3.2 ready for wider use
After months of testing, ArduCopter 3.2 (aka APM:Copter) is ready for widespread use and we invite all users to give it a try.  In order to manage the support load at first it will be available only through the Mission Planner and APM Planner2's Beta Firmwares link.  This link is visible from the regular "Install Firmware" page if you check the "Advanced View" on the Config/Tuning >> Planner page.  On APM Planner2 the "Advanced View" it is under the File menu.
In about two weeks we plan to replace AC3.1.5 with AC3.2 as the default version dispensed by the ground stations.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner.  Please select Help > Check for Updates
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped ssupport for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks the Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release.  Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYawThor's Zombie Run&FollowMePhanivyas's Test, Rob's TradHeli, Christian's Test1&Test2Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more.  If you want to get involved check-out our dev wiki.
  • What have you set as your low volt FS level? You haven't mentioned what the log shows under -CURR for 'Volt'. This should show whether your batt voltage dipped below this FS voltage.
  • Thank's  Philips It's possible a PModule problem? I'm going to try again and check the two  batteries, yesterday I read the log before recharguing batteries.
  • Hi Cala
    Your current draw matches throttle ok, but the low Batt FS could be because the batt voltage dropped below FS level.
  • Today Dplanner advice me that I have a Failsafe, I didn't finish flying time that I ussualy do but land and return to home, them I check my logs and find this strange thing
    3701881788?profile=original the only difference with other times is that I use an older and a newer battery, normally I use two older in parallel, I supposed that I going to fly more time but not, and the low battery alarm didn´t advice nothing. What it suppose the problem? Thank's
    Please note that Copter 3.2 has been released
    http://diydrones.com/profiles/blogs/arducopter-3-2-released
  • I noticed there are myriads of parameter settings for EKF. Does it work well with default settings? Do you use it?
    The weather hasn't been good enough to get any real flight time in to tune my new Sky Hero Spy 750 Y6, but using the default Y6B settings it flew quite well.
  • I would say "suggested" instead of recommended... it'll likely be the default for the next release though so it would be good to check it out and see if you have any issues.
  • Is it recommended that EKF be enabled or not?
  • MR60
    It is indeed not required if you use it on the same board. I intend to use this one as the second GPS and that leaves me the compass free to use on another compagnon board, so I need a ground ref.
