ArduCopter 3.2 Released
ArduCopter 3.2 (aka APM:Copter) has been released as the default version replacing AC3.1.5. This is the exact same version that we invited all users to test two weeks ago.  Users who wish continue using AC3.1.5 can find it under the "Pick previous firmware" version on the MP's Install Firmware screen.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner. Please select Help > Check for Updates.
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO.
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped support for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks to Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release. Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYaw, Thor's Zombie Run&FollowMe, Phanivyas's Test, Rob's TradHeli, Christian's Test1&Test2, Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more. If you want to get involved check-out our dev wiki.
  • oh ya, in my video, when i put my handphone to the ground, its mean my loitering going crazy ...
  • 3702218624?profile=originalthis is my Channel Input and Channel Output Orientation, why on channel 5,6,7,8 that i didnt use, the signal out is full ?? is this normal ?
  • Hi Randy, you are very best and u are my favorite pilot :D
    I use 3DR APM 2.6 clone, and i want to make my quadcopter good in loiter, this is my standart parameter that i have from standart latest firmware AC 3.2.1
    3702218493?profile=originali was calibrate All of things, i use external compas with ROTATION_ROLL_180_YAW_45
    went i try to Loiter, working well, but after around 2 minute maybe, quadcopter going crazy, and i must switch to Stabilize mode to handle it,,
    https://youtu.be/3NYsseI0UVw
    and this is the Datalog, https://www.dropbox.com/sh/vw33igpz9b4mzw0/AABRWjNXUe16OU66Gv3O2c6W...
    Hope you can help me, please
    Best Regards from Indonesia !!
  • how did you connect the APM to L293D??
  • Nope, ESC calibration is under setup, not motor sync. It has disappeared.
    It's under setup now....
  • Has the motorsync test been removed? I can't find it in the CLI
  • In m planner down the octa you have a previous firmwares button, there you can find the 3.15, if you don't able to fly 3.15 too, try to erase all and reinstall 3.2.1 . Good luck.
  • Hello to everybody
    i want to ask how the led lights perform now at 3.2.1
    I have a apm 2.6
    i have see that at 3.2 the lights work like this
    • A4 : Motor LED
    • A5 : Beeper – can drive a piezo buzzer directly (see below)
    • A6 : GPS – will flash with no GPS lock, solid with GPS lock
    • A7: Arming LED
    Can i use to A5 as a motor led and not the buzzer???
    can i use A8 , A9 , also as a motor led??
    If the only way to have leds to my motors , Can i use a y cable to split the signal from A4 to get motor leds for 2 motors??
    Thank you for your time
    @Carl, I'm not sure actually.  It really depends upon whether MichaelO has pulled it into the MP or not (the auto log analyser in the MP uses the central python analysis scripts but it still take a manual step from michael to update the MP).  I'll ask MichaelO
