A big code release tonight--this is the full setup that won the Sparkfun autonomous vehicle competition. Along with general improvements to the code, this is the entire package of autopilot, setup utility and ground station code. It's a full Unmanned Aerial System, not just a UAV! ArduPilot 2.1
  • All the features of ArduPilot 2.0 plus...
  • Supports XY sensor in diagonal postion
  • Requires Z sensor [UPDATE: FMA is no longer carrying those. While we sort out alternative sources, you can buy them from Dean Goedde for $40 (scroll down for price list)
  • Controls throttle if airspeed sensor is attached via the ArduPilot expansion board.
  • Supports desktop setup utility for waypoints and autopilot settings. (Waypoints are no longer manually entered in the code. They can only be entered with this utility.)
  • Last version of the code to support the original ATMega168-based board. Future versions will require the new ATMega328-based board.
  • Field setup procedures are here
  • Get it here
If you are using the expansion board and airspeed sensor, to control the throttle you must solder a wire from digital pin 8 to "MUX IN 3" Desktop setup utility
  • Add waypoints manually; utility displays them on Google Maps
  • Set max altitude, speed, circle radius
  • Set elevator, aileron/rudder trim
  • More features coming
  • Get it here ("ArduPilotConfigUtility")
When using this utility for the first time with ArduPilot, click Write before anything else in order to format the EEPROM. Also, ensure that the "Set RTS on close" box is checked in your serial port's advanced properties (control panel/device manager), as described in our Arduino debugging tips) Ground station
  • Requires free Labview runtime engine and serial drivers (install both. Note: if you've already installed Lego's Mindstorms NXT software you may find you've got a driver conflict, because it's based on LabView, too. Uninstall the Mindstorms software first.)
  • Works with Xbee wireless modules
  • Displays real-time attitude, speed, altitude, current waypoint, heading, distance to next waypoint, etc
  • Displays real time position on Google Earth
  • Get it here
  • Source code is here
  • @Saiful Azuwan: I have tried that too.
    Do you have the 328 board?
  • Just try unplug your gps from the board before read/write.
  • Should I be able to read/write waypoints using the set-up utility on the 328 board?
    I get the message, "Something Wrong!" when I try.
    I initially selected write to format the eprom for the first time.
    @Babis Hatzis, you can use the utility on any arduino, but will not work in 2.0...
  • can i use setup utility with ardupilot 2.0 only to write waypoints???
    @Peter Seddon That usually happens with some generic USB to Serial cables, or port emulators, you can try typing COM7 where you choose the ports and press ENTER...
    Good luck!
  • Oh, BTW, when I send data via XBee from my Propeller AutoPilot program to the ground station, everything seems to work.
  • Mine recognizes com8 but no data into setup utility or ground station. Real Term says data is flowing at 57600 baud.
  • [QUOTE]If someone has a Mac and LabView they can compile our source code and create an executable (no porting required; LabView is cross platform). We'd be happy to host it on our Google Code account. But we don't have Macs so we can't do it ourself.[/QUOTE]
    I can do that next week if you like. I have access to a Mac and all versions of LabVIEW.
    -tychoc
  • Chris,
    How do I get the ground station to recognise COM7 port for the data that is coming from A/pilot? I just have a refresh message when I click on the I/O box.
    Peter
