ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • There's alot of great info on this site. However, the articles can be a bit hard to find because you get so many hits when you search.
    If you have the time, you can trace the history of the Ardupilot project by going to "Blogs > Monthly archives"
    It's actually quite fun to see where all this came from and how the community grew. Well worth the effort (plus you find where all the goodis are - like how to wire up FMA XY sensors)
    Chris is really good at getting back to people with specifics because of his intimate knowledge of his content.
  • Thank you very much space nut. Bookmarked that one.
    Why can´t i get that results when googling it?
  • Yes.
    Here's the link
    It's a good idea to get things working with the simplest setup (no frills) then add the sheild later. The AP code allows you to select this in the header file.
  • Hi again,
    Something not clear to me is if i can use FMA XY sensors with the Ardupilot directly?. I mean without the Shield. The thing is that i made the order without the shield and now i am afraid that i might have some problems. I was so happy to find an autopilot that i did not make my homework before ordering.
    Oh...can i leave stabilazition to the FMA Copilot CD4 and use Ardupilot for Waypoint and RTL?
  • The Ardupilot Shield has a 3.3V power supply and a separate TX/RX interface for your GPS
  • Thank you Chris.
    Just went thru the manual and realized how to do it. My concern is that the Locosysls20033 runs on 3.3V and i can only get 5V from the ardupilot. So i am planning on running the GPS receiver from my EZosd and just use (with a Y cable) the Rx and Gnd coresponding outputs for Ardupilot.
    If i understand well, it can be done.
    Sorry for insisting but i am waiting for my Ardupilot to arrive and i am getting anxious.
    Theodoros, yes, the Locosys module can be used. There's a tutorial on how to do it in the ArduPilot manual.
  • Hi,
    I would appreciate if someone could tell me if i can use my EZosd GPS (Locosys LS20033) to feed both the EZosd and the ardupilot with a Y cable.
    Teo
  • Here's the link
    You may need to buy some stuff
  • Yes, It compiles correctly, so I think i need to burn bootloader. I'll see the support that you say.
    Thanks.
