ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
    Larry: Use the Mission Planner to read from the board and see if it has recorded the waypoints. Which version of the code are you using? There are absolutely no issues with 1.02 but 2.0 is still in beta and may be causing issues on some setups.
    Whooper. That's correct. After the mission is completed, it switches to Loiter/RTL. Switching to manual and then to auto again will not restart the mission. If you want to change the mission in air like this, use APM 2.0 and control the mission commands from the GCS.
  • I am not clear if the reference quoted below re firmware 2.51 is to the version of code on the IMU or the version of the code on the ArduPilot.  Could someone clarify?  Thanks
    Note 1: This IMU can serve as a replacement for ArduPilot's thermopile sensors with the 2.51 code and above
  • Hello, i'm from Portugal, and i woul like to know if ardu pilot con make a r/c helicopter fly from the floor and land it... and i would also like to know the price for the full solution...where can i see it? Thanks.
  • thanks for th vid Darren! its certainly been something that I thought was missing from all the marvelous efforts so far.
    brett
  • Thats great !
    Chris, hehe I dont have any APM yet but ist on the way :) I was just a bit nervous how difficult it may be to use the planner.
    Thank you everyone ! :)
  • I also have the logs for those flights posted on here somewhere... :)
  • really? theres tons that ive seen posted here, and below are a couple i've made
    I have one that ended in a crash, but havent posted it :)
    First stabilazation tests
    Full test 5 waypoints and RTH
    iw28: that's a good idea. We take it for granted now, but it would be useful for newcomers to see how it works. Is that something you can make? I'm happy to feature a good video that walks through the steps.
  • Is it just me, because I havent seen any video, where the ardupilot mega is used in a airplane with waypoints? wish there were any video, that showed how fast and easy it is to upload waypoints and fly!
