I know, the world probably has enough flying machine projects, but here is yet another one. AutoQuad's original design goal was high precision autonomous flight. It took five prototypes before I was happy with the hardware. The current prototype, AQv5, is showing very promising results. In fact, there is little left to do before this first goal can be checked off the list. Using this as a solid base, I intend to continue research, design and experimentation toward vision based navigation for indoor and outdoor use.
Hardware:
- 2" x 2" board with same mounting pattern as the MK FC
- Input voltage ~7.5v => 18v
- High efficiency DC/DC converters
- STM32F103 32bit Cortex M3 microcontroller @72 MHZ
- standard ARM 20 pin JTAG header for real-time debugging
- up to 8 PWM ESC motor control (prefer Turnigy ESC's with custom firmware)
- 2 powered payload servo controllers
- optional ultra sonic range finder
- Spektrum satellite (remote receiver) 2.4Ghz RC radio
- uSD card slot
- optional onboard uBlox LEA-XX module w/battery backup & timepulse capture
- optional female SMA connector for active GPS antenna
- optional external GPS via standard 6 pin connector (EM406, EM401, uBlox, MTK)
- optional onboard xBee module - up to 300mA (2.4Ghz, 900Mhz, bluetooth, etc.)
- optional external radio via standard 6 pin FTDI connector - up to 1A
- I2C bus connector for I2C ESC's
- modular sensor board (SBv5) - 100% analog sensors, EMI hardening:
+ 3 axis acc (ADXL335)
+ 3 axis mag (HMC6042 & HMC1041Z)
+ 3 axis gyro (IDG500 & ISZ500)
+ 2 temperature sensors
+ pressure sensor (MPXH6101A)
+ battery voltage
Software:
- Fully threaded RTOS design written in C - 60% idle
- All sensors read at 113KHz (~1.4M sps total)
- 450Hz motor update rate
- 200Hz attitude, 3D velocity / position solutions
- Full downlink telemetry
- Detailed system state dumps @200Hz => uSD card w/FAT32 FS
- Quaternion based attitude filter additionally producing rotation matrix and Euler angle outputs
- All math in single precision floating point
- Temperature compensated and calibrated sensor suite
- Custom ground station software w/bi-directional command and control API
- Cascading PID control system, velocity based for smooth transitions
- Auto land / takeoff
- Hover position / altitude hold
- Autonomous waypoint mission navigation
- Precise altitude hold indoors
Example of current capabilities:
Design philosophy:
- High performance
- Efficiency
- Ease of development
- Consistency / Repeatability
- Low cost
There is always room for improvement. For instance, I would like to see how much of a benefit using a SPKF (Sigma Point Kalman Filter) would be over my fixed gain navigation filter. Looking forward to the new Cortex M4 uC's with a hardware FPU so that any such math intensive solution can be more easily handled. As I mentioned above, there is a lot of room for work with vision navigation and SLAM. Also interested in propulsion efficiencies which with an eye toward higher endurance. Although the PID based control system works extremely well, I'm interested in exploring different types of MPC (model predictive control) to reduce control costs and increase precision.
I'm wondering if there is anyone interested in joining forces to work on some of the above mentioned or anything else along these lines that presents itself. This is only a hobby for me and I currently have no profit motive. This is definitely not a beginner's project as you can see by my sloppy SMD hand soldering job.
Comments?
It is very very difficult to beat your design ! Superb !
Present Arducopter and UAVX would take long to come at par with yours.
Lew: I've visited your page a few times in the past (great resource), but till just this moment realize that was you:) I have spent many months working with various flavors of SPKF. I've coded them in C, C++ and partially in assembly seeking stability and performance. I even had a small three state running onboard the ARM at a low frequency. There just is not enough cycles available to do anything useful.
Currently a parameter estimation SRSPKF is at the heart of my sensor calibration software, without which I would not be able to achieve current performance levels. I also use the same estimators to tune all flight parameters via offline simulations. I think the SPKF technology can help with a large number of problems, even if it cannot yet be used onboard. We owe Rudolph van der Merwe a debt of gratitude for all of his hard work.
Bill, some SPKF info can be had in this thread, where you'll also find some MatLab code for the Schmidt-orthogonal (soukf) implementation as well, and an soukf without Eigen lib dependency, and a cholesky decomposition substituted for the square-root one. In this thread, I'm blabbering about the SPKF. In this thread, I get tired of arguing theoreticals (hence, the MatLab code that came out in other threads).
Being primarily an STM32 and TI TMS320 (Delfino w/floating-point as well as Da-Vinci DM64 series) user, I'd be happy to "climb on-board" your development team, if you're looking for help.
@Bill
this is my design that use same of your micro ... if you want i can share my opensource managment with you ... do you have an a price of your configuration ?
http://www.virtualrobotix.com/forum/topics/multipilot-20-ap32-building
This is the old one : http://code.google.com/p/lnmultipilot10/wiki/multiboard that had your same form factor .. mk like ..
Regards
Roberto
@Ruben: It's common to fill the empty space of the board on either side and attach the fill to ground and positive (back and front) or sometimes just ground. This provides shielding and also a low resistance / inductance path to keep all components from interfering with each other via the power traces.
@Bill: This is one sexy design please do start a blog or page where you can fill in the details of this board and share your progress, I think that would be great.
I particularly like the insane update rates. What freq are the PIDs on arducopter running at?
-Aurelio
-Aurelio
