For those following this saga, version 6.1 of the AutoQuad board is complete and has passed initial testing. I have taken the 5.0 design and added features that should make it more flexible and expandable while increasing performance. Here is a summary of specifications:
Hardware:
- 2" x 2.5" main board with MK mounting hole pattern
- Input voltage: 6.5v => 18v
- High efficiency DC/DC converters
- STM32F215 32bit Cortex M3 microcontroller @ 120Mhz (1MB flash)
- Standard Arm 10 pin 0.05" pitch SWD connector
- 14 general purpose PWM controllers / receivers (powered or un-powered)
- Dedicated Spektrum satellite (remote receiver) 2.4Ghz R/C radio connector
- uSD card slot driven by 4bit SDIO capable of 100Mb/s transfer (up to 32GB storage)
- optional onboard uBlox LEA-XX GPS module with battery backup and timepulse capture
- optional u.FL active GPS antenna connector
- optional external GPS via standard 6 pin connector (EM406, EM401, uBlox, MTK)
- optional external bi-directional telemetry radio via standard 6 pin FTDI connector - powered up to 1A
- I2C bus connector for I2C ESC's (or other I2C devices)
- onboard IMU options:
+ optional 9 DOF analog sensors (3x RATE, 3x ACC, 3x MAG) w/EMI hardening
+ optional VectorNav VN100
- daughter board options:
+ 9 DOF analog sensor board
+ VectorNav VN100
+ High performance SOM (Sytem on Module)
+ Any combination of the above
- Two barometric pressure sensors
- Battery voltage monitor
Software:
- Fully threaded RTOS design written in C - 75% idle in flight
- All (15) analog sensors read up to a rate of 276.8KHz (~4.2M sps total)
- 100Hz => 800Hz PWM motor update rate (requires custom ESC's at rates >450Hz)
- 200Hz attitude, 3D velocity / position solutions
- Full downlink telemetry
- Detailed system state dumps @200Hz => uSD card w/FAT32 FS
- Quaternion based attitude filter additionally producing rotation matrix and Euler angle outputs
- All math in single precision floating point
- Temperature compensated and calibrated sensor suite
- Custom ground station software w/bi-directional command and control API
- MavLink protocol support
- Cascading PID control system, velocity based for smooth transitions
- Auto land / takeoff
- Hover position / altitude hold
- Autonomous waypoint mission navigation
- Precise altitude hold indoors
What I call the general purpose PWM controllers are 14 connectors which can be used for PWM (or any other digital) signaling. Each one can be optionally unpowered or powered with 5.0v or 6.5v (depending on the RECOM part used.) Since each port is connected to a dedicated timer line on the uController they can be used for input or output. This means you can have any combination of motors / servos / acoustic range finders / LED's, etc. that you can image with power up to ~1.2A. With the input capture capability, you could also use them to connect a traditional multi-channel R/C receiver.
I have included two pressure sensors (2nd one optional) so that fixed wing users can monitor airspeed. Or, you could use one as a failover or combine the two to get smoother altitude measurements.
There is a lot of flexibility when it comes to the IMU. First there is the option of using the onboard analog sensors:
+ 3 axis acc (ADXL335)
+ 3 axis mag (HMC6042 & HMC1041Z)
+ 3 axis gyro (IDG500 & ISZ500)
+ 3 temperature sensors
These must be calibrated by the user which can take a lot of time and aggravation. For the person who would rather pay someone to handle this calibration for them, a VectorNav VN100 can be soldered directly to the main board and used as an IMU.
With the 2x20 pin connectors a daughter board can be connected which can accommodate an analog or digital IMU as well. In fact, you could have combinations of onboard and external IMUs used simultaneously for failover or co-witness configurations. Since these connectors contain many analog and multiple high speed digital communications channels, a SoM can be connected such as a GumStix Overo with a 720Mhz Arm Coretex A8 processor with Vector Floating Point hardware running Linux with gobs of RAM and flash storage and optional bluetooth and WiFi radios. This will allow easy experimentation with complex navigation filtering and the exploration of vision based navigation algorithms.
Here is a picture of an external VN100 attached as a second IMU:
I have received a lot of positive feedback on my past designs as well as a lot of requests for hardware that I could not fulfill so I have decided to try to find ways to make this board available to those who want to build a machine around it. I can't say exactly when, but I hope to be able to announce hardware availability through various sources in the not too distant future.
Update
Any boards available? I like to fly/test this board.
Frank
Great, look forward to seeing your progress - let me know if you decide to run some extra dev boards.
MPU6000: A mag and pressure sensor can always be added to the carrier for the 6000. I recall your reasoning for sticking with the analog sensors. MPU6000 has been talked up a lot by various folks, but I haven''t seen any actual comparison data. Suppose I'll stick with the VN100, since despite the cost it's the only platform with a calibration at this price level - and access to the analog output ensures I'm not reliant on any compromises in the MPU6000 for the digital conversion.
STM32F4 : you bet. I've been playing with it for a few months now. I'll eventually post my progress.
MPU6000: I have not tried it so I cannot say, but from AQ's perspective it could only be used as a digital ACC and GYO. It is missing MAGs and I have a bias for analog sensors.
Hi Bill,
Wondered if you started working with the STM32F4 - you mentioned an interest in a previous post with the desire to implement a SPKF in place of the EKF.
Also, do you still advocate the the VN100 or do you think the MPU6000 would be comparable (assuming raw sensor values are used? I assume the MPU6000 is a calibrated system similar to the VN100....?
Thanks,
joe
Yeah ! some news from Bill !!! :)
AQ does not use the attitude solution information coming from the VN100, only the raw sensor data for incorporation into my own attitude / navigation filters. It's only used as an IMU.
Of course I am talking about Vectornav development board's GUI, Sensor Explorer. If you have used any?
Hi Bill,
I wonder what are your filter tuning parameters and active tuning parameters for the quadrotor?
Fatih
Hopefully Bill has been secretly finalizing and manufacturing the boards
