BlimpDuino home page
3689304736?profile=original
BlimpDuino is a very low cost open source autonomous blimp. It consists of an Arduino-based blimp controller board with on-board infrared and ultrasonic sensors and an interface for an optional RC mode, a simple gondola with two vectoring (tilting) differential thrusters, and ground-based infrared beacon.
It is available as a commercial kit from the Maker Shed or the DIY Drones store for $89.
[UPDATE: The current Blimpduino kit has been discontinued. Stay tuned for a new design in 2012]
  • What else you'll need
  • Instructions for making the kit are here.
  • Instructions for loading the code are here
  • Correct LED/servo/motor behavior modes are here
  • Instructions for using Blimpduino are here
  • The parts list is here
  • The discussion forum for teams using Blimpduino in the FIRST Robotics aerial robotics demonstration is here
  • If you want to build your own board from scratch, the necessary files and component lists are here
  • If you want to print out a cool DIY Drones sticker like the blimp above has, here's a pdf.
3689304786?profile=original
The Blimpduino board is the core of the kit. Features:
* 17 grams, with ultrasonic and IR sensors.
* Controls two motors and one vectoring servo.
* Built-in RC compatibility (can read two RC channels--throttle and steering)
* Designed for a 7.4v LiPo battery; has an automatic power cut-off at low voltage to protect the battery.
Here's the board with the ultrasonic sensor removed, so you can see the Atmega168 processor underneath it:
3689304861?profile=original
Here is a video of BlimpDuino in flight, using a breadboard version of the controller board:
At the moment, we're using Pololu IR beacons as the ground beacon, but we'll eventually release our own, open source, versions of them, too.
Here's the board on the gondola with vectoring thrusters and the optional RC receiver:
3689304811?profile=original
The commercial kit consists of the following:
--BlimpDuino board, with all SMD parts already soldered on
--Other through-hole components, to be soldered by user (easy)
--A very simple laser-cut plastic platform for the board, battery, optional RC receiver, and motor components
--A servo, gears and motor shaft for the vectoring (thrust tilting) function
--Two motors and props
--One IR ground beacon
--52" mylar envelope
The following is a chronological list of posts describing the development of the project. This is mostly for those who want to follow along and learn about Arduino-based robotics. If you're interested in autonomous blimp development and want to know more about BlimpDuino features, they will give you some insight into the evolution of this project.
  • I would like to mention for anyone interested, that I was able to get my blimp filled at Kroger (grocery store), for $2.99. This appears to be a much better deal than the party city helium tanks, though I can't comment on the helium purity yet.
  • If anyone stumbles across a wild Blimpduino in the bay area with "Faceblimp" written on the side, it might be mine. It escaped today, you can find details at http://fryfrog.com/2010/07/24/missing-faceblimp
  • Wow, thanks for the very quick reply, I sent you my address. Thanks a lot!
    David, sorry to hear about the missing part. PM me your address and I'll fedex you one.
  • Well, my kit (ordered from Maker Shed) didn't contain the motor driver IC, so I will have to wait for them to ship me the chip before I can finish my blimp, but I did write a python program to control the blimpduino through a serial connection. Here it is http://docs.google.com/leaf?id=0B2YlF2kPfadHZDQ2YTAwMDAtNGQ5Zi00ZTA... as well as the modified arduino code here http://docs.google.com/leaf?id=0B2YlF2kPfadHMmJjMDQ5ODUtNjc5Ny00NjU.... I know this code isn't very elegant, but it works as far as I can tell without owning the proper motor driver IC. I am hoping in the future to add a wireless module of some sort so I can control it from my pc wirelessly, as well as recieve the serial communications from the blimpduino. I am considering these http://www.robotshop.com/seeedstudio-433mhz-low-cost-transmitter-re... for thier low weight and good price. Any input is welcome. Thanks
    EDIT: I will write up some documentation if there is enough interest, but it is pretty simple and self explanatory so I don't think it will be a problem.
  • Thanks, I will probably pick one of these http://www.robotshop.com/sfe-serial-enabled-16x2-lcd-white-on-black...) up with my next order.Good work on the blimpduino, that looks like an great price for everything that comes in the kit.
    P.S. FedEx just showed up with my blimp while I was typing this message :)
    David, if you're using all the regular sensors there are not 6 free pins. I'd suggest serial instead, which is free.
  • I am thinking about ordering an lcd for my Blimpduino (which should arrive today), but I need to know whether it has enough pins to drive one. As I'm sure you know it takes 6 pins to drive a standard character lcd. Does the Blimpduino board have 6 pins (digital, or analog, which if i understand correctly can also be used as digital pins) that are currently unused? If not I guess I will have to order a serial lcd if I want one. Thanks
    Okay, thanks for the feedback. I've incorporated your change in the code on the site.
  • No, same code, just found your line in the code.... so it might be that a 1sec wait is not enough for this receiver (Corona RP6D1); unfortunately no start-up time listed in the manual....
