MkII H frame quad now flying.
Frame weighs about 60g less than Mk1 with much more room and accessibility to the nose sections. The arm O rings mounts are more firm than the Mk1 but vibration levels about the same. All RAW x,y,z accel vib about +- 1.5. Its possible to fly without reversed motors but the YAW rate is still much better with them reversed. As the arms are enclosed there is no problem if an O ring brakes and it has been flown with two missing on the same side.
I am now working on an internal nose gopro gimbal.
Antonie –
Will try to get some dimensions up soon. For the time being its 510mm between motors – not diagonal.
Robert –
Yes they are quick to replace but if one fails there may be other things to repair. I the max total current I have seen was a 80A spike – usually 14A. They are 30A each, should be OK.
Gary –
Yes silicone O rings. They look twisted but thats because its needs a 90deg turn to line them up if you see what I mean. The MK1 had a 65g ali pad which was stuck to a foam pad – same size. I first put the new 75g aluminium pad on 4 20x20mm foam pads at each corner. It didn’t fly very well – with frequent twitching so I jammed up the pad to make it more rigid which cured the problem. I can only put this down to the lag that you are concerned about. Too much weight on too soft support. I didn’t expect that. Anyway the new ali pad is covered in lightening holes now and weighs about 45g and is 100% stuck to the foam pad. The vibration is up a bit but it flies much nicer. Lesson learned, low vibration is good but you don’t need to take it to extremes. The other thing that has changed – on the Mk1 the tube clamps are 80mm apart but the MKII they are 120mm. This considerably reduces the YAW imbalance displacement so it works with normal direction motors, but is still much better with them reversed.
I did try it with direct APM mount and the vibration was low and flew nice BUT if I lose an O ring and the motor tube bottoms out on the frame it may put the vibs over the tuning limit.
ESC
http://www.unmannedtechshop.co.uk/30a-multi-rotor-esc-simonk-rapide...
Motor
http://www.fast-lad.co.uk/store/products_multicopter_motor_4008-530...
not recommended for 14” props without modified prop driver or direct to motor props. –(shaft will slip). Shafts weak. I have replaced the shafts many times after minor ground contact. I have a 1/8 silver steel rod to cut them from.
Battery
4s 5000mah – usually I just use one but it will take 2.
O rings
http://export.rsdelivers.com/product/rs/bs115-sil70/silicone-o-ring...
Hi Vince,
Congrats! this looks great : design, functionality and creativity.
Love it
Hugues
This design is very sleek. I've been sketching up and working on a design of my own but haven't actually "turned the wrench" just yet. Your placement of the ESC's is ingenious! If you have QD plugs on either end, and you create small niche' cases around them, you could use industrial velcro or a latch system to hold them in place. In the event of a bad ESC, you simply unplug the ESC via the QD's and install a new one. Really ingenious design! Good work!
Airship.
Nice job mate!!!!!
Great Job I like your air plane as well. The only way to get some thing durable is make it your self That is about he size drones will become in the future to be commercially viable they will have to carry a reasonable pay load . Have a Great day!
Beautiful plane Vince and I am certain nobody is ever going to accuse you of doing things the easy way.
A bit like this one?
Really, really nice Vince,
I notice that your frame moves very little in relation to the arms on your O-ring arm suspension and that your performance level is very high.
Are those silicone O-rings? Triple wrapped and look to be at least 1/8" cross section I imagine they snub frame / arm displacement pretty quickly.
As you may know I have been concerned that this in the middle of the airframe vibration solution could induce significant and deleterious response delays between the flight controllers sensors and the power response, but that does not seem to be the case here.
Do you have any secondary vibration control for the APM itself or is it fixed directly to your fuselage?
I think your H design is excellent and my next Quad is going to take a lot of cues from your design.
I have a small vacuum forming system I made and I have already laid out a CAD version of a somewhat smaller Kydex fuselage.
You really need a bit of front end prop clearance and forward projection for good video options and the H design supports that very nicely.
If you wouldn't mind, what are the actual motors, ESCs, props and battery setup that you are using?
