A pan & tilt system for Skywalker / X8 wing for installation inside fuselage.
Here you have some pictures for inspiration and stl files if any should be needing this P&T.
Here you have STL files if you want to cut or print your own piece.
Enjoy
Enjoy
Do you have the cut files in.dxf?
I'm going to use that in two of my birds. TYVM!
Looks like a great Idea, I cant wait to see it installed.
Hi, it looks very good, but it is not obvious how you do the pan, is there another servo hiding that turns the pullys?
You will also be needing this:
http://www.technobotsonline.com/mxl025-plastic-timing-pulley-30-tee...
http://www.technobotsonline.com/mxl025-plastic-timing-pulley-18-tee...
http://www.technobotsonline.com/mxl025-rubber-timing-belt-60-tooth....
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=...
