It's been quiet on my front, but that was because I was redesigning ESC's (for multirotors and AP's).
Most of the ESC's for multirotor use the SimonK firmware on a relatively simple Atmel microcontroller. There's a single control wire running from the autopilot to the ESC, which is a signal proportionally dictates how long the mosfets are left open and as such command the torque on the motors.
And that's pretty much all there is to an ESC... No signal/wire coming back to tell the autopilot how that particular motor is doing or what the rpm or current is, it's just a "command wire". That sounds a bit antiquated for 2014.
So this picture is of an ESC dev board I first started on, here using the Allegro A4960 chip for simplicity. Shipping to Brazil takes time, so before it arrived the design already morphed into something new, so that's why the board looks unused. Both the MCU and driver chip changed on the newest development board version and I introduced testing points for oscilloscope readings; this project is about to get serious!
What are the features that I think an ESC for a modern multirotor should have?
1. Send the rpm back to the AP; for logging. I see people posting logs to request help figuring out what went wrong, but the log only states the "pwm out" for each motor, which is in no way a guarantee that the motor actually did that. So we need some feedback that states what the motor was actually doing, not what it was commanded to do.
2. Overload detection; the ESC's know what the current is and warn for overload situations.
3. Current & velocity control; neither current nor rpm is actively controlled as a proportional measure to the input PWM signal. So the control loop for the AP spans the IMU, motors, ESC and props, which is a large loop with lots of variables. This ESC will run one or two 'inner loops' and become responsible for achieving either torque or lift and run at a much higher frequency than 500Hz. What you get is that some variables no longer impact the control loop of the AP directly, which should make the vehicle more stable and likely more responsive.
4. Field Oriented Control; The flyback diodes next to mosfets typically burn energy in trapezoidal drive implementations, which increases the heat on those mosfets. This happens because the mosfets close suddenly. The motor coil wants to resist that change, so you have a current that has nowhere to go except through that diode. In sinusoidal control, there's always one mosfet open for any coil, so the current always has somewhere to go, which means the flyback diodes won't get used, so you don't lose the heat.
5. FOC; better efficiency, because the current is always perpendicular to the magnetic field. This may come at the cost of max. torque (related to motor inductance and then only about 5%).
6. FOC; lower torque ripple (1/2-1/3) vs. trapezoidal drive, so hopefully less vibrations, less whistling.
7. Send current readings back to the AP; another opportunity for precisely logging what goes on near the motors. This could be helpful to detect ESC/motor/prop health (bad bearings, prop drag, etc)
8. Configuration; the AP can reconfigure ESC's prior to flight or when in maintenance to tune it for a specific motor.
9. Motor monitoring; if the motor stopped, shorted or the mosfets misbehaved, the ESC can shut down immediately and advise the AP. The AP can then take additional action.
10. Opportunities for automated ESC tuning specific to the motor/prop in use.
The way I see this ESC make a difference is when abnormal situations occur. The current AP's cannot be informed of failure, so it would simply send a signal to "run faster", which, guaranteed, has a disastrous effect to mosfet or motor and could therefore worsen the situation. Soon as the AP is informed something is wrong, it could sound an alarm, activate a chute, disable the counter motor... you suddenly have options!
To spur innovation in this area, I'm considering to setup a kickstarter and actually manufacture around 1.000 or so at a professional PCB house. Aren't these features indispensable for an ESC made in 2014? Would you back it?
@ Gerard, my 5c, please make sure it supports at least 8s if not 12s lipo.
I'm hoping that someone designing ESC takes into account net-lift efficiency--the efficiency of the propulsion system after it lifts itself. Engineers designing components for multi-rotor craft typically do no take into account the weight of the component and that impact on amps relative to it's contribution to lift. This can work both ways. It's good if a component weighs less and performs as good as something heavier. It can also be good if a component weighs more but decreases the required watts to lift. ESCs are an example of the later.
Little know behavior of ESCs:
- If you have a motor drawing 6 amps at max load, one might think that a 12 amp ESC would be optimal (weighs less and is 2x over designed).
- But in reality, a 20A to 40A ESC will be more net-lift efficient even though they weigh more.
- Why? No one seems to optimize ESC design to lift itself first.
- Easy? Yes. Just breadboard different components and test the impact on net-lift.
Just food for thought. Hope your design also does a better job at efficiency. It will appeal to a wider audience if it does.
Also, in testing, i've noticed that ESC firmware doesn't do that good of a job in finding or quickly finding the most efficient pulse signal at a specified torque. Your firmware might address this. If you ever want the ESC tested (during any phase of development), let me know. I'll do it gratis.
Very convenient!
ESC are the last piece of electronics that need to be updated to 2014 tech!
Go on!
Very nice objective. However I do not see how you will implement points 1, partly 7 and point 9 as these depend on feedbacks sent by the motors to the ESC somehow. You project would thus need specially designed motors able to send to the ESC some kind of feedback.
Nice.
If the price would be reasonable, i would probably back it. 4 to 10 esc, depending on price and size options.
Most important for me is stable work, and generating less magnetic field, if possible.
A thought occurs...
If you can drive all three phases, could you use this to drive a "double" motor? Ie one set of poles above another (slightly offset to each other), and two rings of magnets? By staggering, you can introduce a situation where the bell of the motor is alway under torque (no deadspots between magnets)
Of course, I'm no motor expert, but I do like to daydream :-)
Yannick: ESC32 doesn't implement FOC, so something is new...
John: Field Oriented Control is basically sinusoidal drive, where you have 3 mosfets in operation at any given time (so all phases are "driven"), of course never the high&low mosfet for any phase. When a low or high mosfet is about to close, the other is already opening. That's why the flyback diodes shouldn't be necessary for normal operation, because the current always has a path to go. For trapezoidal drive this can be different, because they switch a mosfet pair at any given time and use the third non-operated coil to measure back emf, so when they switch and allow for some dead time, they may have a tiny period where there's a voltage spike, which is where the diode breaks down to release the current.
Stunning stuff - take my money!
This is a great idea and get ready for a huge software group this can be modified in unlimited ways if designed correctly would use this as a main board for some small 1or2-motor applications.
Hi Gerard
Great forward thinking idea. not only for security but for tuning and operation as well. not for everyone on a day by day basis but for great for a developer to improve his machine with results not guesses.
Put my name down. I'm all for more efficiency and information.
1
2
3
4
5
of 5 Next
