Good data from Doug Weibel today, who was testing the uBlox GPS vs the onboard absolute pressure sensor on ArduPilot Mega with his NexStar Mini EP. In general the uBlox is performing great. And we love the onboard datalogging on APM!
Doug explains the modest data diversion between the two sensors:
"You can see that in the area from roughly 1600 to 2500, there is greater difference between the two altitude measurements. This coincides with when I let my son fly the plane and took it out of fly by wire mode and put it in manual. He was busy trying to get the little NexStar Mini EP to do some aerobatics. Since he was spending a lot of time in very high bank and pitch angles I would guess that the uBlox performance was suffering and the baro altitude was more correct."
-John
For what it worth, I notice that the GPS, other than for a brief span at the start of the graph [run]:
- consistently measured higher than the baro
- and that the difference (between the GPS & baro) is more or less consistent throughout the graph run.
Question:
- what antenna does the GPS use, and where have you placed it on the airframe?
Thanx
Patrick
-Beall
1
2
of 2 Next
