Skywalker is now in a new version made of EPO foam. Much stronger foam.
Length: 1180mm
Wingspan: 1680mm
Wing Area¡G35.5dm2
Wing Loading¡G36.6
Recommendation
4 x 9g Servo
3S1P 11.1V 2200mAH-5000mAH
Motor: 2215-1200KV or 2815-900KV
Propeller: APC-9045E 9060E
I think this platform could be the replacement for the smaller Easystar if it's possible. What do you think?
Skywalker is now in stock! This is not the EPS foam, this is the new EPO version - much stronger foam.
See more on this Skywalker FPV UAV platform.
I found some data on rcgroups:
3000mAh: 30 minutes
6000mAh: 50 minutes
10000mAh: 80 minutes << break even
12000mAh: 80 minutes << no more benefits
14000mAh: 75 minutes << starts descending
From npole's post on http://www.rcgroups.com/forums/showt...h#post18069450
Fantastic Andrew - would you say one could fit 2 x 5mAh and push it to 90 minutes plus?
@Hein, I use a 5Ah 4S battery, and typically fly for a bit over an hour, but I tend to fly pretty gently
Well, mine's on it's way!!!!
Please could someone recommend a battery pack for maximum fly time??
Brian
I am in the middle of building a CNC machine to build my own plane designs, but I would much rather skip that step at this time just to get flying again.
Hooks, let me know.
What I have heard that the Skywalker should be the best FPV UAV platform. and very easy to transport, can carry many equipments, more crash resist, and is bigger than the easystar and will fly safer, longer and higher, should also be very recommended.
