Announcing our new product listings for mid-summer 2013!
_______________________________________________________________________________________
3D Robotics Y6 and X8 Multicopters - RTF and Kit
We released the Hexa-to-Y6 conversion kit a few weeks back, and now the complete Y6 DIY package and Ready-To-Fly are available. A Y6 design is able to withstand a single motor out scenario, provides a more open and stable view for cameras, and doesn't weigh as much as a traditional Hex (because it uses less parts). It features folding arms to make ground transport a painless affair. This is our new go-to multicopter at 3DR: better performance than a quad at about the same size!
If six motors aren't enough for you, there is now the X8. With the same coaxial motor design as the Y6, but with four arms. This brute is amazingly compact, it's actually smaller than our quads in the front to back dimension, due to the wide angle of the arms. This is the platform to choose for flying your heavy camera and gimbal setups. The redundant nature of this vehicle is a valuable trait when carrying expensive gear or flying over difficult terrain. This vehicle can lose a motor and remain in a stable loiter with almost no disruption . The 3DR X8 is available ready-to-fly only at this time.
APM 2.6 and 3DR uBlox GPS with Compass
APM 2.6 is the same APM 2.5 you know and love, but with one valuable change: this revision of the board has no onboard compass, which is designed for vehicles (especially multicopters and rovers) where the compass should be placed as far from power and motor sources as possible to avoid magnetic interference. (On fixed wing aircraft it's often easier to mount APM far enough away from the motors and ESCs to avoid magnetic interference, so this is not as critical, but APM 2.6 gives more flexibility in that positioning and is a good choice for them, too). This is designed to be used with the new 3DR uBlox GPS with Compass, so that the GPS/Compass unit can be mounted further from noise sources than APM itself.
Note: APM 2.6 requires an external compass for full autonomy. If you are using APM 2.6 with a GPS module that does not have a compass sensor, you must use a stand-alone external compass. We recommend this one with this cable.
New GPS shown as it comes, in a nice enclosure
The board, inside the enclosure
You can also use the new uBlox GPS with on board magnetometer (compass) with your existing APM 2.5, To modify your board, follow the directions here.
_____________________________________________________________________________________________
If you have been wanting to add first-person-view (FPV) capability to your vehicle, our new FPV package gives you everything you need in one kit (including batteries). All connectors have been built in the factory and designed to give you an easy plug-and-play experience -- no soldering required! On-screen-display is provided by our MinimOSD board for real time data telemetry. This is an important safety and convenience feature for anyone flying FPV.
All of these items are available for order immediately.
The FPV kit is ready for shipping today.
The Y6 DIY package and APM 2.6 will ship on July 15th.
Note: RTF Y6 and X8 units will follow the normal 1-2 week turnaround. You'll find those and more on our new RTF store here: http://rtf.3drobotics.com/
Nice Job!
Hello. Some time ago I was ordered couple of GPS+Compass. At that sort period of time these units was sold with out case. Now I'm interesting in purchasing only cases. Is it possible?
But the way I'm completely satisfied with that unit. Have no any problems with compass. And GPS show me up to 15 satellites.
Used this useful unit for the demo: http://store.3drobotics.com/products/servoswitch-v10-kit
X8 motor out demo video added to the original post!
It is important to thank Leonardo DaVinci, Dr. George Bothezat, and Stephen Edmond Oehmichen -- The fathers of rotary flight, the later two being pioneers of the multirotor in particular. In the early 1920's, Bothezat and Oehmichen both made many flights in their multirotor creations
Leonardo Da Vinci started it all with his sketches of rotary wing craft,
although some people have theorized that he was inspired by even earlier Chinese designs.
Wouldn't that be excellent irony...
Great new stuff 3DR guys.
The new APM should make things a lot easier for using 3.0
The tri/hex and quad/oct are extremely nifty.
And that is an excellent price for a truly complete drop in FPV system.
Good Job!
Thanks Pablo! I got it fixed now. I appreciate the heads up :-)
Pablo, both of the links are working for me. http://store.3drobotics.com/products/apm-2-6-kit-1
Are you talking about the ones in this blog post?
Kevin, I'll say thanks on behalf of the people who actually did the work :-)
How's Hawaii?
Really like the folding feature
Regarding GPS on a stick. These are great for a quick and easy way to fold it down. 3DR should look at stocking them.
http://www.goodluckbuy.com/gps-folding-antenna-base-gps-fitting-sea...
1
2
3
4
5
of 6 Next
