APM Copter 2.9.1.b has been released to the Mission Planner and is also posted in the downloads area.
2.9.1b is a maintenance release incorporating changes to 4 default parameters that have been optimized since 2.9.1 was released. There are also 4 minor bug fixes. There are no code function changes or additional features.
The changes are:
1) reduce default INS_MPU6K_FILTER to 20hz
2) reduce InertialNav Z-axis time constant to 5 (was 7)
3) increased max InertialNav accel correction to 3 m/s (was 1m/s)
4) reduce yaw_rate P default to 0.20 (was 0.25)
5) bug fix for alt_hold being passed as int16_t to get_throttle_althold_with_slew which might have caused problems if you climbed over 320m.
6) bug fix for throttle after acro flip (was being kept at min throttle if pilot switched out of ACRO mode while inverted)
7) bug fix to acro trainer to do with roll correction
8) prevent cli from being entered more than 20seconds after reboot.
Users are recommended to:
Update Mission Planner to 1.2.41 and
Update their flight code to 2.9.1b from the Firmware tab on Mission Planner. There is no need to go through a new configuration process in the Mission Planner.
I've just put AC3.0-rc3 into the new downloads area here and in GitHub and the MissionPlanner should start dispensing it shortly through the Beta firmwares link.
Improvements over 3.0.0-rc2
1) bug fix for dataflash erasing unnecessarily
2) smoother transition to waypoints, loiter:
intermediate point's speed initialised from copter's current speed
3) Ch8 auxiliary function switch (same features as Ch7)
4) safety checks:
Warning to GCS of reason for pre-arm check failure
ARMING_CHECK parameter added to allow disabling pre-arm checks
Added compass health and offset check to pre-arm check
compassmot procedure displays interference as percentage of total mag field
5) WPNAV dataflash message combined into NTUN message
6) allow TriCopters to use ESC calibration
All feedback welcome. I think we're getting close to a final release.
A bit of testing today.
I generally test each item, one at a time, and don't progress until I'm happy.
So I've been stuck on alt hold since 2.91b came out. It's been back to terrible with massive jumps and drops again. Finally I ripped out my 1260 sonar (again), and the quad does alt-hold like a dream. I guess I have to buy yet another sonar (my third) for it to work (1340).
So I moved on to loiter. And it seems perfect. I did have 12 satellites locked in for awhile, and there was no perceptible movement at all. It's still a little twitchy (but holding in place), and I'll need a gimbal if I ever get serious with video.
No auto flights yet on this firmware. RTL test will be next, then after that full auto course with some ROI.
(One thing at a time).
I'm getting very confident with my flying, took it up to 160 feet, no fear. :-)
I was just editing the 3.0 code to reverse the motors and noticed the H frame options with it already done!. Must have missed that.
Good news.
Cant decide if I should give it a try or wait for final release. Any big gotchas in rc2?
Ah, yes. I forgot to put a notice here!
In the last mission planner version, i see a new checkbox next to the calibrate accel button. The text next to this checkbox seem to indicate a version number. What is the purpose of this checkbox? Should i check it or not , hacing 2.9.1b ?
Roberto S, this is going into the wrong thread for some strange reason so had to put it as a new post!
There was discussions about that awhile ago, it is to do with the throttle trim setting I believe that the autopilot thinks it needs compared to the actual throttle setting for a hover (it is supposed to auto learn that setting depending on battery power available). It used to be called throttle trim, not sure what it is called now as I am not near my quad to check.
Just a curiosity question about the loiter, having trimmed out the bad habits for this release the loiter is not bad at all, certainly acceptable for what I currently need it to do. However, when I am in a stable hover and then select loiter the quad starts to climb, if I leave it it will keep climbing, so why doesn't the autopilot correct that?
The only way I can stop it climbing is to reduce the throttle slightly then it is happy and stays put.
4
5
6
7
8
of 12 Next
