ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • My questions are about the compassmot routine.
    Does compassmot need to be run again if the prop size is changed?
    Can I run it with 10" props and then fly 12" props without running compassmot again?
    TIA,
    Rick
  • Stefan, thanks for your reply. I did change the loiter speed and auto speed from 500 to 750 cm/s. It was better, but it seems the pitch is to small as I want. I mean the nose must be more down like in stabilze mode, the angle must be more.
    please can someone give me advise which setting should be changes.
    the stabilize mode is perfect, never flew "stabilize" with the naza, now i have to fly on myself.
    Flying missions is perfect too, but as mentioned the pitch is to small, i have the idea if the nose is more down the quad will fly much more stable.
    Dick Gerritsen
    dutch mountains, the Netherlands
  • Hi Randy,
    I notice that the gps gets a 3D fix it blink in blue, will that be possible to tweak in FW?
    I'm thinking if it's possible to include a patter of blink/s that indicate hdop and satellites.
  • Do I need to do a full setup again after loading 3.1-rc1 over 3.0.1? ie, leave all my PIDs as are. Can I just load and redo the compass cal and then fly?
  • Some results of a test flight.
    Firmware 3.1rc2
    Frame TBS Discover
    Motors 1000 kv, ESC 30A
    weather: less wind
    standard settings, only loiter p =0,5
    frame: V
    Stabilize mode: good reaction. Flies well.
    loiter mode: slowly reaction of the sticks, at low flights, the quad goes up and down, high flight: quad keeps hight stable
    auto mode: perfect flight, about 7 wp.  But slowly, might fly faster
    some questions:
    Loiter: how to make the quad faster
    Loiter: can the hight also be controlled by gps at lower hight (like naza)
    Loiter: how can the reaction of the sticks be more aggressive
    Auto mode: how to make the spead faster?
    Dick Gerritsen
    Munstergeleen, the Netherlands
  • One of the possible values of the variable WP_YAW_BEHAVIOUR is 3: Face along GPS course.
    Can someone explain what this value does and how it differs from 1: Face to next waypoint?
    Best regards,
    Henk de Groot
  • Hi,
    I am hoping someone can give me some advice. I have been reading that flight time can be increased quite a bit by using motors that are around 400kv, with larger props.
    I would like to try to change my motors with some of these but I am not sure what I am looking for, is 400kv good or should I go lower 340kv or a bit higher 580kv. also I would like to use the esc's I have which are blueseries 40a flashed with simonk FW.
    My goal is longer flight time. and I am not sure if I want to use these on a quad or octa-quad. probably a quad
    thanks for any help,
    John
  • I flown my copter today and while doing auto land, at about 1m from the ground, the copter suddenly moved. I immediately switched back to stabilize but too late. fortunately damages are only blade and a bit of landing gear.
    can anyone check my log and tell me what went wrong? is it a famous GPS glitch?
    by the way I saw my GPS data does not have similar duration of record than others like altitude... is that normal?
    2013-09-20 21-31 37.zip
  • This's my video for test AC3.1-rc2 Loiter test when have strong wind about 7-12 knot. It still tuning not finish.
  • I was setting up a new frame a couple of days ago, and got to the point of running the compasmot.  Got the throttle up to about 50%, and all four of the motor mounts snapped.  Ooops. 8-(
    It is a quad, 24" square on the Avroto 2814-11S motors, running 4S through simonized BlueSeries ESC's. ArduCopter 3.0.1 on a DIY Drones 2.5 board.  The motor mounts are made from 2mm G10, and the props are APC 12x6 Thin electrics.
    I had the quad on the ground, with the props upside down to push it down while running the compassmot routine.
    3692835237?profile=original
    Now that I have rebuilt the frame, and made it stronger, my questions are about the compassmot routine.
    TIA,
    Rick
DIY Drones via Twitter
Dec 12, 2021
DIY Robocars via Twitter
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31, 2021
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29, 2021
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25, 2021
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23, 2021
