ArduCopter-3.0 ready for wider use
ArduCopter 3.0 is ready for widespread use.  To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner.  The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position.  This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
  • Safety improvements:
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right.  The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3691031698?profile=original3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3dr frame can be seen in the image below.
3691032069?profile=original
3691032034?profile=original
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to Marco, DaveC and the rest of the beta testers for putting their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying.  They are excellent!
3DR Quad Set-Up Suggestions        http://www.youtube.com/watch?v=33Tl_rjhQEE
AC 3.0 "Live" Compass Calibration  http://www.youtube.com/watch?v=DmsueBS0J3E
AC 3.0 CompassMot Setup                http://www.youtube.com/watch?v=0vZoPZjqMI4
AC 3.0 Pre-Arm Checks                      http://www.youtube.com/watch?v=gZ3H2eLmStI
AC 3.0 Fence                                         https://www.youtube.com/watch?v=HDnGdo54o-4
AC 3.0 Maiden Flight Checks             http://www.youtube.com/watch?v=NOQPrTdrQJM
  • When will the official release come out
  • Hi Randy and Developer Team.
    My Loiter Test result was awesome, Thanks for your hard work!!
    Any suggestions to improve loiter performance are very welcome..
    I've added a video about the new Fence feature is AC3.0.  Then fence is fairly easy to set-up and hardly needs an introduction but you might at least take some comfort in seeing it actually work.
  • Ohooo,new Mission Planer graphic..nice...I wonder is there solution for this;when i go and fly to some place where i was not before and have no internet connection there is no maps stored i just get blue screen..is it possible to store maps somehow?I do have Google Earth on my Notebook but that does not help.. usually i use Ovi map bcs. of higher resolution...
    Randy, what must we look at to chase down a little toilet bowling problem?
    I had a flight during the week which seemed perfect, today in a different location Loiter was bad again. I redid compassmot and the compass dance with battery in.
  • Does the order of operations matter between doing the compassmot and live compass calibration?
  • Loiter and RTL
  • Randy, got a question.  I am going to give 3.0 a shot on my 450 heli soon.  One of the things I want to do is try undo the autotrim I have done.  As you know, heli's need a bit of roll to the right to hover in place, to counter the tail thrust.  But I wonder if this is going to confuse things more than anything.  I'd like to try having the "level" set to actual level, and then let the Loiter controller automaticly compensate for the tail rotor thrust.  Not sure how it will work out, but I'm going to try.
    Which parameter should I zero-out to unlearn the autotrim I have stored?
  • Thanks for helping, all works good (90%). Stab, Alt-hold and Loiter.
    RTL is not working, the quad is holding the position but not moving to home position. Any idea what to check?
    Itzik
