Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Randy, do you mind taking a look at my message on the previous page. I'm thinking it's an auto landing triggered by GPS but am not sure that is showing up in the log. It's never happened before. Only with rc12. Did some checking get more strict on GPS health in rc12? Up until rc10 I never had this happen.
Could some one explain the Altitude Parameter on the DO_SET_ROI please? if Spline Waypoint 1 is 10 M and SET_ROI is 8m and Spline Waypoint 3 is 10 M will that produce a Dip in altitude? or is that parameter largely ignored? Also still trying to Clarify the Cicle Radius if it is in deed meters or centimeters. The Mission Planner Full params Shows it as Meters.
thanks in advance having a great time flying RC 10, just upgraded everything to RC12 and hoping for a sunny weekend. KUDOS all around Dev Team!!
Circle Radius is in cm (older FW it's in m)
i currently have the newest Beta Mission Planner and RC12
i can now certifiably confirm i am losing my mind. i know it said meters in the Circle Radius because i changed it to 10 m. when i reconnected from 1.3.10.4 Mission Planner to double check i Now see in Mission planner 1.3.10.4 i see cm. dont get old people, senility is close behind :P
Now if i can just get the DO_SET_ROI Altitude parameters question answred, i will go off quietly to my rock and ribbet with the frogs and drool :P
LoL
don't worry you won't be alone :) reserve me a spot :)
https://groups.google.com/forum/#!topic/drones-discuss/B09cI-XTASA
And in my case Mission Planner does not retrieve the descriptions correctly. So APM Planner on the Mac it is.....
video taken a couple weeks ago in Hawaii with 3.2rc5 (Y6, pixhawk)
Excellent cinematography! Was your gimbal setup 2 axis or 3 axis?
thank you! it's 3 axis (DYS gimbal). I don't know if it's the Y6, but with a 2axis yaw just never was solid enough.. even on calm days.
Randy,
Could you please tell about log détails regarding EKF and AHRS?
Also When arming whitout GPS, what home position drone take?
73
74
75
76
77
of 262 Next
