ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Doug,
          I had a similar problem with my Y6 trying LiIon cells - lower motors always at ther thrust limit.
          I had 14 x 4.7 props on all motors.
          I now use 13x4.5 on upper and 14x7 on lower motors, so now they have all nearly the same thrust.
  • Hi,
    Loaded RC9 a few days ago, flew great! I did a quick FPV yesterday and was nice. It was a fresh install and all calibrations were done.
    Decided today I would go for a good FPV flight and I put it in POS HOLD while I fitted my goggles and I started climbing in POS HOLD then all the sudden things got wonky, I tried to come down, flipped to RETL but I had some issues and then when I switched back to STAB it just wouldn't listen and and above my head i could hear my motors accelerating and it was going higher. I took off the goggles to try and watch it and bring it down but it just kept going up. I am thinking I had baro issues but not sure! I kept trying to switch between stab and RETL and had my throttle super low, (finally it switched to Stab and although I couldn't see it I saw in the monitor it was flipping and falling. I tried to spool my motors up but they couldn't grab.
    In the end it landed in a forest and it was very high up! It landed maybe 300 meters from where I was and just by luck I ended up finding it by trying to spool my motors. with arming it.
    Luckily I am an ok climber and went up with a buddy and retrieved it!
    PS It was windy today!
    Issues were around 1 min mark to 2:30 then you could see me arming it over and over again to hear the motors.
    2014-09-20 14-26-47.log
    • Glad you found it!!!!!!!! Hey what gps were you using?
    • After looking at it some more, I see my CH8 which is my PWM RSSI drops below 1500, (another issue I have been trying to fix) I think that may be the culprit in causing some issues. but not sure. Let me know if you guys have any feedback would love to know.
  • Maybe I found a bug. In Auto, LOITER_TURNS works perfect when Dir=0 (25 m radius circle clockwise). If Dir=1, it rotates clockwise but radius 0? I read manual and see, that for counter clockwise rotation Dir may set to -1. I not tried this...
    • if it is a bug, please leave it. I Like to have Loiter_turns with 0 Radius:-) I was looking for that . I´ll try it out when at home!t
      But I found a bug in Condition_Yaw. The Parameter relative or actual is always actual Heading (rel/act;0/1).
      • I tried DIR = -1. Also turns clockwise with 0 radius.
  • Hi Randy and Dev Team
    tested today RC 9 Pixhawk
    Guidet Mod    OK no problems
    Follow me      OK no problems
    Landen no problems motor switch off
    Auto Mode OK no problems
    I could find no errors. the version runs very smooth
    greeting
    Rainer
    • Rainer are you using APM 2.6 or Pixhawk ? also are you using DroidPlanner  Beta 2.6 for follow me ?
      • Whats Droid Planner 2.6 Beta? does it work with AC3.2?
        Also where can i download it for android?
        thanks.
